Very odd horn problem
Old May 15, 2024 | 09:45 AM
bsmyla's Avatar
bsmyla
4wd Low
So at 05:30, the horn on my 2001 Excursion Limited starts sounding continuously - one long tone. I go out and unlock the doors with the key fob, and when I turn the key, the horn stops. I close the door, lock the truck and as I'm walking away it begins sounding again. Not wanting to be bothered with it further at the time, I disconnect the battery and go back to bed.
I reconnected the battery later, and had no problems for about a week. Then it happened again. Had to disconnect the battery again.
Couple of weeks later, I'm driving at about 20mph, and the horn begins sounding again, like someone's laying on the horn button. I stop the truck and open the door, and the horn STOPS when the door is open. Fine, I close the door and continue. When I get up to 15-20mph, the horn starts AGAIN. Stop the truck, open the door and it stops. Ok, so I leave the door cracked open and start moving again. Horn starts again around 15-20mph and doesn't stop until I pull the fuse.
Any ideas about what to look for?
Old May 15, 2024 | 09:54 AM
WE3ZS's Avatar
WE3ZS
Did any or all of these horn events follow a rain event?
Old May 15, 2024 | 10:05 AM
bsmyla's Avatar
bsmyla
4wd Low
No, no rain event at the time.
Old May 15, 2024 | 10:42 AM
oharal's Avatar
oharal
I can't find the page of the electrical schematic for the horn system but if it goes through the GEM I'm thinking you have water in it. OR possibly there is something in the slip ring for the horn causing it to short the horn button.
Old May 15, 2024 | 05:04 PM
bsmyla's Avatar
bsmyla
4wd Low
Does the Excursion have a slip ring, or a clock spring? I would consider the clock spring to be a possibility if the horn sounding wasn't dependent on the door being open and / or vehicle speed.
Old May 15, 2024 | 05:09 PM
oharal's Avatar
oharal
Obviously I don't know what your root cause is, but I'm pretty confident the problem isn't actually related to the door or the speed even though I believe you that it really seems like it. I'm an electrical systems engineer in the off highway equipment industry so I'm pretty familiar with automotive and adjacent electrical systems even though I still can't find the page of the schematic I wasnted I can tell you there is no interaction between vehicle speed or doors and the horn itself.
The schematic I did find at least had the horn switch and called out "horn slip ring" specifically.
Old May 15, 2024 | 06:08 PM
01__Excursion's Avatar
01__Excursion
Might be worth poking around the GEM to verify no moisture issues..
Old May 15, 2024 | 06:11 PM
oharal's Avatar
oharal
Bingo! There's a gremlin in your box lol
Old May 15, 2024 | 06:35 PM
01__Excursion
Other tings to check are,
Chafing in the gear shift stalk where it enters the steering column (pivot point)
Potential cracked/fatigued clock spring
And from my own experience after replacing my steering wheel airbag, were the pressure/forces needed to activate the horn switch. My original airbag had an extremely light touch to activate the horn, my new OE airbag module requires much more pressure/force to activate the horn.
Old May 15, 2024 | 07:17 PM
bsmyla's Avatar
bsmyla
4wd Low
Examine the GEM it is. Now, where is that beast located?
Old May 15, 2024 | 07:29 PM
01__Excursion
https://www.ford-trucks.com/forums/1...-location.html
The best referenced thread...
https://www.ford-trucks.com/forums/1...ater-leak.html
Old May 17, 2024 | 04:30 PM
jspence105's Avatar
jspence105
if you haven't already done it I'd replace the horn button. When mine went it would go off are crazy random times. it's easy to get to and was like $2 at the scrapyard. well dang it's not cheap to buy a new one.
Amazon Amazon
FLD45
Jul 18, 2021 08:58 PM
Chardagha#1
Jun 9, 2021 03:57 PM
Davydee
Jun 29, 2018 02:13 PM
justincmw
Feb 23, 2018 04:03 PM
goldman
Feb 19, 2004 06:59 PM
