Sponsored by: Real Truck
2012 F-250 No Dome Lights
Old Feb 6, 2026 | 03:04 PM
Aaronw12's Avatar
Aaronw12
Originally Posted by WWR
My '11 developed this symptom several mos ago. Based upon research I assumed it was the BCM, but haven't done anything about it.
I will say I had to pull my BCM to replace the blower (this was AFTER the dome light failure and not related to the failure) and even on my '11 XL it's got WAY more plugs than should be legal. I suspect as you get closer to '16 and with a Lariat/KR package the BCM only gets more complex.
I'd gladly return to the days when my dome light was triggered by a momentary door switch and maybe throw in a crude timer for battery safety -- although even the timer is optional. I don't really need my dome light to softly fade out or for all lights to come on with keyless unlock, or 98% of the things the BCM does.
Sorry, what were we talking about....? Oh yeah: how many of us have lost dome lights because of overcomplication!!
You said it! I also have a battery drain that’s been somewhat intermittent for the past year. Doing some troubleshooting, it seems to lead to the TPMS. Then during testing everything turns to normal and the spike in resting drain seems to go away. Guess this is the world we live in. I noticed a feature in the BCM on ForScan listed as “Battery Saver” it’s disabled. Wondering if I should enable it. Maybe will help with my issue.
Old Feb 6, 2026 | 04:07 PM
WWR's Avatar
WWR
That might be the BMS which fortunately SuperDutys did not get. There's another one: you're no longer supposed to just replace a battery without "telling" the vehicle it got a new battery.
However I don't actually know what the feature you saw truly is.
Old Feb 6, 2026 | 10:27 PM
Aaronw12's Avatar
Aaronw12
The Self Test Fixed it! DTC's B10F1 - key in switch, B1175- Driver's Door Ajar Switch, B1305- Hood Switch, and B1313- Interior Lighting Output were the codes that came up. The Driver's door was open when I performed the test, I do have the hood switch jumped with a wire because the alarm kept going off. Other codes anything to worry about?
Old Feb 7, 2026 | 06:44 AM
projectSHO89's Avatar
projectSHO89
Yep, that's the one that indicated the FET protection circuit was tripped for the dome lights. You likely also had a U1000:00.
As long as the underlying fault has been fixed, you're in good shape.
Note regarding that video above as well as any conclusion that the BCM must be replaced. It is premature to go to that conclusion without also checking for either U1000 or U3000 BCM DTCs. The first is non-fatal and resettable by successfully running the BCM self-test with the scan tool (after the underlying short circuit is corrected). The U300 is a permanent failure and requires the BCM to be replaced in order to completely repair the system. Replacement of the BCM requires the use of a scan tool to first upload the module configuration and then to download that data into the new BCM so that it is properly configured.
Old Feb 7, 2026 | 12:58 PM
Aaronw12's Avatar
Aaronw12
I didn’t see a U1000 or U3000, it’s possible I wasn’t looking in the right place in the program. I believe my short circuit was due to a water leak in the roof above the rear domelight. The PO had a NMO style antenna mount above the light with no antenna on it. The single o ring that was left in the nut of the mount wasn’t keeping water out. Water had dripped through the dome light and came out around the map light switch onto the backseat. I don’t remember exactly the process of events but sometime around when I fixed the leak is when the dome lights stopped working.
Old Feb 7, 2026 | 02:53 PM
WWR's Avatar
WWR
I kinda want to kidnap @projectSHO89 and lock him in a shed and force him to diag all electrical problems for me.....kinda like how bad actors kidnap nuclear scientists. Who's with me??
Old Feb 7, 2026 | 09:19 PM
Aaronw12's Avatar
Aaronw12
Do you know if the 2008 Superduty works similar? Neighbor has a 2008 XL, dome light and rear cargo lights haven’t worked for years. I don’t see a Body Control Module listed for that truck though. Is it controlled by the Smart Junction Box?
Old Feb 8, 2026 | 02:07 PM
projectSHO89
Ford use the SJB and BCM terminology somewhat interchangeably. On the '08, both the interior (dome) and the cargo lights are operated by FETs as has been discussed in this thread. The two functions are on two separate circuits.
Start by checking the fuses F09 & F10 in the SJB. If both are good, proceed to scan the SJB for any relevant DTCs. Note that the DTCs for this older SD truck will be different than those previously discussed.
Lol! I'm an expensive pet....
Old Feb 8, 2026 | 02:45 PM
Aaronw12's Avatar
Aaronw12
I'll check that, I imagine if there is a FET that needs reset in the 08 it will do like the 12? When the scan is complete if no errors are found the lights will turn on?
Yes, maybe next you can figure out why the '12 is draining the battery in a few days. Have been investigating that for some time, thought it was narrowed down to the TPMS but not certain yet.
OFE James M
Mar 20, 2024 08:51 PM
dannyual767
Sep 6, 2021 09:20 AM
AzSuperDuty
Nov 16, 2014 05:39 PM
garmford
6.7L Power Stroke Diesel
Mar 25, 2013 12:33 PM
wlmgshap
Electrical Systems/Wiring
Mar 20, 2001 11:08 AM
