1965 F750 VIN Decode
Warranty Number:
F75WU370341
W.B.:
174
Color:
J
Model:
F752
Body:
81A
Trans:
J
Axel:
G3
Max. G.V.W. LBS.:
23000
Cert. Net. H.P.:
173
R.P.M.:
3600
D.S.O.:
440128
F75 = F750
W = 332 4V Lincoln-derived Y-block, 173 certified net HP @ 3600 RPM
U = Louisville Assembly Plant
370341 = 1963 numerical series, January 1963 production
174 = 174 inch wheelbase
J = Red
F752 = F750, 23,000 lbs GVWR
81A = Conventional closed cab--Standard
J = Clark model 250V five speed direct transmission
G3 = 16,000 lbs capacity two speed rear axle (Probably Eaton), 6.50 / 9.04 ratios
No front axle code, possibly part of the special order
23000 = 23,000 lbs GVWR
173 3600 = 173 certified net HP @ 3600 RPM
440218
44 = Twin Cities District Sales Office
0218 = Special Order Number
What wheels do you have on it?
https://www.ford-trucks.com/forums/1...l#post19232301
