Ford F600 vin decode
F61 = F600 gas, 4x2
D = 330 2V HD FT gas V8
C = Ontario Truck Plant
C67110 = 1968 numerical series, December 1967 production
156 = 156 inch wheelbase
J = Red
F610 = F600 gas, 4x2, 21,000 lbs GVWR
E81 = E = Red Crush Vinyl & Red Cody Pattern Woven Plastic / 81 = 81B Custom Cab. (possibly, this is from another decode. I do not have the full upholstery info)
M = Clark model 285V five speed direct transmission. (look at the plate again, it should say "transmission" above or close to above this letter)
F8C
F8 = Eaton model 13802 Two Speed Rear Axle / 6.33/8.81 / 15,000 lbs. Rear Axle Capacity.
C = Ford Rockwell-Timken 6,000 lbs. Capacity Front Axle.
440807
44 = Twin Cities District Sales Code
0807 = Special Order Number. Hard to say what was a special order, as the usual suspects of engine, trans, axles & color are covered. Could be something else.
F61 = F600 gas, 4x2
J = Red
F8C
440807
