Driving on Ice.
Old May 6, 2024 | 09:26 AM
ASFC27FTFBQ's Avatar
ASFC27FTFBQ
Driving on Ice.
I’ve changed everything having to do width steering, except the Pitman arm.
The steering feels very sensitive, like driving on ice. It does track straight; it goes where the steering wheel is pointed.
I put in 4 degree Moog caster/camber bushings. I was told by someone that to gain the most caster; insert the bushing with the fat end of the outside ring towards the rear of the Ex. So I did. Results are on the attached printout. ASA Certified Mechanic from Moog said the fat end goes to the front. If he is correct, how come I get these numbers or are the numbers the opposite of what I need for caster. (Not totally happy with the camber settings).
When I take my Corvette to the track, I dial in a little toe-in for the rear tires, so at high speeds, the car will easily track straight. From the attached printout, it looks like I have a small amount of toe-out. How can I get the rear toe-out to be toe-in? I’m thinking a shop that does this by blow torch’s and huge vice grips.
Thanks for any help.
Old May 6, 2024 | 11:43 AM
Kobra's Avatar
Kobra
Your alignment looks okay, not great.
I would say you need .1* toe IN on both sides, and 0* camber on both sides. Caster looks good, as anything above 5-6* is where solid axles like to be.
The touchy steering could also be a tight steering box. You could try backing the steering nut off 1/4 turn on the steering box and see if that loosens the steering feel.
Edit: I forgot to ask whether your track bar, tie rod ends, and drag link are in good condition? I noticed a "sliding, icy" feeling when I would take turns on my Excursion, like the front end was sliding back and forth in the turn, and knew I had an old worn out track bar. Once I swapped it out with a PMF HD adjustable bar and tightened everything down to spec, the icy, sliding feeling went away completely.
Old May 6, 2024 | 03:11 PM
oharal's Avatar
oharal
The caster seems okay... not sure how much more you can get out of these trucks by shimming. I have a 2WD so I genuinely have no idea. I'd want a better alignment in toe up front than that. I think the guy got lazy and wanted to go home. If you want to numb the front end a bit, a tiny bit of toe in is helpful. I prefer 0 toe for optimal tire longevity.
You have a log axle in the back. There is no camber or toe adjustment...they are completely fixed to the 0 camber 0 toe setting. The values on the sheet are bogus, hence they are grey.
SNIPER168308
May 8, 2020 06:23 PM
HJM/F250
Jan 9, 2016 07:05 AM
wantobenav
Aug 18, 2006 10:20 AM
Scrapiron66
Jan 6, 2004 09:38 AM
obxpilot
Bronco II
Dec 10, 2003 11:36 PM
