Adding ATF C6?
Old May 3, 2024 | 08:54 PM
Deadbuck's Avatar
Deadbuck
Adding ATF C6?
Fluid level is low. I want to add some more fluid. I have no clue what fluid was in there when I purchased the vehicle. Is there anyway to tell the difference in fluids?
Half the websites say you can not mix Type F and Dexron at all ever or it will destroy the transmission. The other websites say no problem mixing.
Should I just add some type F? Should I just wait and get the fluid changed? Is it ok to drive it a little low? It’s been flaring between 2-3 gear recently.
Old May 3, 2024 | 09:27 PM
tbear853's Avatar
tbear853
What year model C-6 would help, as would reading the dip stick, Let us know. I "think" was about 1976 or 7 they changed the spec. Type F was earlier, has different friction.
Dex/Merc is a good sub for the CJ spec ...I was cautioned to base it on initial fill, my '77 was original with the CJ fluid and never been rebuilt.
Old May 4, 2024 | 12:48 AM
440 sixpack's Avatar
440 sixpack
You can mix DEX and Type F. they're basically the same oil it's the additives that differ,
You should be using type F, other oils can cause more slippage my trans guru says.
Old May 4, 2024 | 06:51 AM
Deadbuck's Avatar
Deadbuck
dip stick says ESP-M2C138-CJ oil
Old May 4, 2024 | 07:12 AM
tbear853's Avatar
tbear853
CJ had a yellow look, but as I understood it from an industry guy,it used whale oil as an ingrediant, it is "No More". Dex III/Merc or just "Dex/Merc" is good, and I still have some saved. Searches now indicate Mercon or Mercon V is OK.
I've never tried type F in mine, nor will I. Knew a guy who did, it changed to harsh shifting. Don't know what long term effects were.
Old May 4, 2024 | 07:58 AM
Deadbuck's Avatar
Deadbuck
Do you think I would be ok to add a quart of type F for the short term until I can get the fluids changed or just wait it out and baby it if I need to drive it?
Old May 4, 2024 | 08:22 AM
Rubiranch's Avatar
Rubiranch
Same topic, different thread. Check the last comment.
ESP-M2C138-CJ Fluid Alternative
I do know my '76 PS likes Type-F better than PS fluid.
My 2007 Lincoln calls for Mercon V.
I'm guessing it would work for a C6 too.
Old May 4, 2024 | 08:23 AM
Rubiranch's Avatar
Rubiranch
If you don't know what's in there I'd use Type F.
Old May 4, 2024 | 09:53 AM
440 sixpack
The main difference between F and the others is the slippage you'll get. unless you're drag racing or heavy towing you'd probably never notice the difference, older Ford automatics were designed for type F. just do it.
Old May 4, 2024 | 02:04 PM
beardedcap's Avatar
beardedcap
i’d verify, I know they changed to mercon in 77. The former Ford trans engineer guy that posts on this forum, Mark Kovalsky is constantly adamant about using the right one. Afaik the clutch material is different depending on which one it uses. I know my 82 bronco took mercon
Old May 4, 2024 | 02:46 PM
440 sixpack
Yes they changed in the late 70's. Op didn't say what year he has so since he was talking trpe F i assumed it was an earlier one. maybe not.
I wouldn't be afraid to use Type F in any c6 but if it calls for mercron that's what I'd use. seems like DEX II III is what substitutes for if I recall.
Old May 5, 2024 | 09:57 AM
Rubiranch's Avatar
Rubiranch
When a C6 gets rebuilt I would have to think the clutches and seals would be upgraded to accept the newer fluids.
Old May 5, 2024 | 11:19 AM
Viper Pilot's Avatar
Viper Pilot
I’m having trouble understanding why this is such an ordeal. Just fill the darn thing with some type of fluid. Don’t run it low and “baby” it. Even under normal load you’ll smoke clutch packs due to lack of fluid.
Honestly, I don’t know why you even want to change the fluid. If it smells burnt, your trans is done anyway. No amount or type of fluid is going to fix it. In fact, when a transmission is older or on the way out you’ll make the situation worse by changing the fluid because you just drained out all of the friction material from the clutches that was suspended in the fluid and helping them to apply. Add something in there to the appropriate level for now. Later, just drop the pan for a filter change and refill again. If the fluid is burned, you’re in for a rebuild eventually no matter what.
Old May 5, 2024 | 06:50 PM
Deadbuck's Avatar
Deadbuck
Half of the stuff I read online said Do Not Mix atf fluids. The other said no problem to mix.
I can’t get a good read on the dipstick. Wiped clean, reinstall and remove and fluid is all up and down the dipstick. No idea how much is in there.
Old May 5, 2024 | 06:55 PM
beardedcap's Avatar
beardedcap
when are you checking it? While running and hot right? it can be hard to see but I know it's doable. It'll only be hard if you just added fluid through the dip stick tube and it will take a while for it to all run down into the pan
