ESP-M2C138-CJ Fluid Alternative
Old Mar 19, 2007 | 09:52 PM
vesuvius5402's Avatar
vesuvius5402
Hello Everyone,
My transmission dipstick says to use ESP-M2C138-CJ fluid. I do not see any ATF in stores that references this number. I hear conflicting opinions about what is safe to use.
I have some HAVOLINE ATF that says it is safe for DEXRON II, IIE and III and I have some VALVOLINE MAX LIFE that says it is good for DEXRON III and MERCON.
Can I use one of these? If not what can I use?
Thanks for your help
Old Mar 19, 2007 | 10:14 PM
Franklin2's Avatar
Franklin2
Is this for the 1981? Does it have a c6? I put Dexron II in mine, though now I think they call it Dexron/Mercon III.
Try this link.
http://www.autozone.com/servlet/UiBr...3d800a4cbd.jsp
Old Mar 19, 2007 | 10:19 PM
vesuvius5402
Yes it is for my 1981 F-150 with a C6.
Old Mar 25, 2007 | 03:33 AM
KULTULZ's Avatar
KULTULZ
Post
CJ was supersceeded by DEXRON III/MERCON.
Old Dec 2, 2012 | 04:46 PM
Joseph Gendron's Avatar
Joseph Gendron
ESP-M2C138-CJ
To be clear, to my knowledge this particular specification is an outdated Mercon (Ford) specification, any universal transmission fluid that is suitable for mercon should do fine, though picking a good one should make the transmission last a lot longer, especially if you use a synthetic. The only Mercon transmission fluid that I specifically know is not compatible is "Mercon SP" because it is the wrong viscosity, I also might stay away from "Mercon LV" as I do not know if it is backward compatible. Most any universal transmission fluid that is suitable for "Mercon V" should be compatible as well though because of the higher levels of friction modifiers you might notice smoother shifting between gears. My personal preference is usually for synthetic fluids like "Redline's D4ATF" but the valvoline max-life is compatible & more than adequate.
Heliguy
16
Jan 31, 2024 05:56 PM
HomerCamper
26
Dec 6, 2017 05:12 AM
señorEddie
Dec 10, 2015 08:09 PM
jpurvis79bronco
Apr 18, 2014 10:00 AM
shore
1978 - 1996 Big Bronco
Feb 20, 2014 10:54 AM
