Recommendations on PCM
Old May 3, 2024 | 10:26 AM
dunecj2a's Avatar
dunecj2a
I want to replace the PCM on my kids 94 F350 460. I reached out to Flagship one and they quoted me $750 for a new one with lifetime warranty. Couple of places that I tried online did not carry anything for under 99’s. Anyone know of other places I can check?
Old May 3, 2024 | 10:36 AM
Duke5A's Avatar
Duke5A
What's wrong with the unit you have? If the caps are swelled (common problem) you could fix it yourself for about $5 worth of parts.
Old May 3, 2024 | 10:43 AM
IBLDBLUE's Avatar
IBLDBLUE
I had to replace mine. I just went with O'Reilly's. Quick, easy, cheap, warrantied. I kept my original as I plan on getting it fixed and having a quality backup.
Old May 3, 2024 | 04:13 PM
dunecj2a's Avatar
dunecj2a
Did they special order? On the website it says unavailable.
Old May 3, 2024 | 11:35 PM
seschenburg's Avatar
seschenburg
My experience with Flagship One a few years ago.
Bought an ECU. It ran for less than the warranty period. Went through the motions of an RMA, and then got ghosted. Opened the case and found that the capacitors were original and leaking. I was able to fix them myself and the unit fan fine afterwards, but still. Never buy from Flagship One.
IOW, if they say "Tested and Certified", or whatever, and use the term Warranty somewhere along the way, it in no way means that the item is really a quality part.
AaaaND the warranty, though time-based, when you read it through, really only covered a single repair/replacement. Their prices are high and would easily cover that one-item fix.
My advice, never buy from Flagship One. Just fix the one you have.
Old May 4, 2024 | 09:15 AM
IBLDBLUE's Avatar
IBLDBLUE
Yea, they did. 24 hours later I had an ECM. But as I understand it, it could take up to a few days.
Old May 4, 2024 | 05:11 PM
Nonofordf150's Avatar
Nonofordf150
I replaced mine with a cardone for safety, it lasted me 6 months, overnight I had the fuel pump running constantly, so I put the original one back, I plan to have it repaired the cardone just in case but I find that the repair of the cardone brand is not reliable at all.
Old May 5, 2024 | 05:55 AM
manicmechanic007's Avatar
manicmechanic007
I got a new one for mine off Ebay for 427
Saved my old one and I will replace the caps someday.
Lifetime sure sounds good, but I would be worried about availability of another one in 10 years
Will they give you your 799 back if they cannot provide a replacement in 20 years?
Old May 6, 2024 | 05:39 PM
dunecj2a's Avatar
dunecj2a
Did you give them the part number or vin?
Old May 6, 2024 | 06:49 PM
wwhite's Avatar
wwhite
for that price, I’d go aftermarket new.
i watch the local used part outs find computers from 20-100, resell for the same after fixing the capacitors. Don’t have any 460, I’ll look around.
Old May 8, 2024 | 11:42 AM
dunecj2a's Avatar
dunecj2a
I would be concerned about replacing the capacitors with the correct ones and soldering them properly. Electrical has never been my strong point. I don’t have enough experience or knowledge with circuit boards to spot any other issues.
Kids truck has that 1500-1800rpm stumble and abs/cel lights that come on and off intermittently. For piece of mind I would like to fix or replace since he is doin alot of traveling
Old May 9, 2024 | 07:11 PM
My4Fordtrucks's Avatar
My4Fordtrucks
Those are two completely separate systems that do not communicate with each other.
Lbrewer83
Dec 31, 2021 06:17 PM
Christian A
Nov 16, 2020 07:24 PM
williamldarby
Oct 21, 2019 02:33 AM
Areyouliving
18
May 8, 2017 10:05 PM
ZJRICK
Jul 15, 2013 08:04 AM
