PCM Compatability Help Please
Old Jul 11, 2013 | 07:25 PM
ZJRICK's Avatar
ZJRICK
I'm wondering if a PCM from a 93 will work in a 94 as long as all the other details are the same about the vehicle.
Much of what I have read states that any replacement (whether used or reman) should have the same part number. But if your donor is from a different year, then you cannot have the same part number, right? I mean the 2nd digit of the engineering number is the year, so that seems like a no brainer, right?
I have a 94 E350 with 460 & E4OD Trans - Original PCM is F4TF-12A650-YA
Donor is F3TF-12A650-JA.
I am being told that this came from a 93 version of my vehicle and that this is 100% compatible.
My internet searches on the donor PCM tell me it is for a 1993 E350 with 460 and E4OD Trans. Of course this search typically sends me to one of several reman sites where there is essentially no inventory available for a re-manufactured one for the 460 engine. But at least I can look up part numbers and pretend like I can actually buy one.
I guess I'm just nervous about this donor PCM and am looking for confirmation from someone more knowledgeable than I. I've not been able to find anything that specifically gives us a cross-year compatibility chart. Wouldn't that be nice!
Assuming there are no issues with the donor PCM, have I found a legit donor PCM?
Old Jul 12, 2013 | 01:23 PM
MIKES 68 F100's Avatar
MIKES 68 F100
wrong forum
Old Jul 15, 2013 | 08:04 AM
ZJRICK's Avatar
ZJRICK
Sorry about that. If moderator wants to move it, that is okay by me.
For what its worth, I put in the donor PCM and so far so good. Engine sounds healthy, no KOEO, CM OR KOER codes.
Tucsonan
Nov 25, 2016 09:00 AM
ZJRICK
Aug 2, 2013 09:45 PM
JOHNSHO
Aug 9, 2011 09:44 PM
amberbo9998
Dec 7, 2009 01:20 PM
