MPG ?
Old May 2, 2024 | 12:52 PM
  #31
2021F350's Avatar
2021F350
Originally Posted by jcb206
And how did you do that?
With some SnakeOil AKA (EnviroSave metal treatment), a 5 STAR tune, and AmsOil gas treatment to (clean out carbon deposits)... Total cost of about $1,200. but now spending about $2,000 a year less for gas with better, noticeably better performance... My MPG went from...
13.0 to 15.8 MPG empty winter driving. 21.5% better. EDIT; why didn't it get this with the factory settings...???
8.9 to 11.3 MPG loaded summer driving. 26.9% better. EDIT; Why didn't it get this with the factory settings???
14.5 to 20.1 MPG best summer /empty driving... 38.6% better. EDIT; Why didn't it get this with the factory settings...???
Old May 2, 2024 | 12:58 PM
  #32
4wd6.7L's Avatar
4wd6.7L
....I knew we were missing the part that says, and you too can have this for just 3 payments of $19.99. By the way, none of that has anything to do with Ford or it's buyers not caring about MPG's.
Old May 2, 2024 | 01:17 PM
  #33
2021F350's Avatar
2021F350
So... Why didn't my truck get those higher MPG numbers before...??? With just the FORD factory set up...??? Come on lay it on me, I can take it...
Old May 2, 2024 | 02:37 PM
  #34
johndeerefarmer's Avatar
johndeerefarmer
Originally Posted by ptnaps
I read the 2024 f350 crew cab with 8' bed should get about 15mpg city, why am I only getting 10 or under mpg?
The 6.7 diesel MIGHT get 15 city and 21 hwy. The 7.3 no way..... If you want fuel economy you bought the wrong engine.
Old May 2, 2024 | 02:41 PM
  #35
CBEllis's Avatar
CBEllis
Yep - you're right, but these are unloaded MPG's with the 6.7L non-high output; I can get high teens in-town (unloaded) and low 20's on the highway (again, unloaded).
OP needs a diesel to hit those numbers.
Old May 2, 2024 | 03:26 PM
  #36
ATC Crazy's Avatar
ATC Crazy
Top Answer: 10
Yup. But if MPG's is a concern to the OP, that means money is most likely a concern. The added cost of a diesel, added maintenance costs, and added fuel costs, means even if the gasser gets worse mileage, it's still cheaper to operate.
Now, if the OP is just wondering why his truck isn't getting what the salesman said it would...well...welcome to the world of low life lying scumbags....also known as dealership employees.
Old May 3, 2024 | 08:50 PM
  #37
ptnaps's Avatar
ptnaps
Trailering
hmmm, ok thanks for the info. I didn't just take their word about the mpg. I did some research and saw that it was getting closer to 15, not under 10. It is what it is. It's brand new, stock tires, it has the 10 speed tourqshift and 4.30 electronic locking axle and I'm very easy on the gas. I had a 2004 f-350 with over sized tires, a heavy front bumper with a winch, added springs and I was getting 12 mpg. I guess I figured too, 20+ years later it would be a little more fuel efficient.
Old May 3, 2024 | 08:54 PM
  #38
4wd6.7L's Avatar
4wd6.7L
Where did you research to find 15 MPG in the city? I could see that being an average combined (city/hwy), maybe.
Old May 3, 2024 | 09:17 PM
  #39
Painted Horse's Avatar
Painted Horse
Your salesman was quoting the mileage for the 6.7L diesel engines.
My 23 6.7L HO F350 Long bed. Gets those number. Pretty consistently 20 mpg empty freeway and 15-16 mpg city, and 11.5 mpg towing my 13,000 lbs horse trailer.
So either he just forgot what engine you were looking at. Assumed all Long beds got the same mileage, Lied or you heard his quote diesel mileage when you were thinking gas mileage.
Old May 3, 2024 | 10:00 PM
  #40
GAZZILLA's Avatar
GAZZILLA
My 7.3, 4.30, heavy 34.5” M/T tired, 2” air deflector truck gets 12.5-13.5 mpg small town driving (very little time sitting at lights). It gets 16 mpg @ 65 mph, 15 mpg @ 70 mph. Towing a 4k, 10’ tall travel trailer at 70 mph it gets 8.8 mpg. All at 5k-8k feet elevation.
Old May 3, 2024 | 11:52 PM
  #41
Hwkns's Avatar
Hwkns
…and 4.30 electronic locking axle and I'm very easy on the gas.
4.30’s sounds pretty short. You could change the pumpkins to 3.55 or so to reduce RPM’s and probably get better mileage.
Old May 4, 2024 | 07:59 AM
  #42
jade97's Avatar
jade97
My 2022 7.3 Tremor averages around 12.5 mpg city & I do see about 15.5 highway.
The 2002 F250 V10 4:30 AT I had for 9 years got 12 mpg no matter what the conditions were (except towing).
The 2011 F150 3.5 3:73 AT got 17 city, up to 21 highway (if using premium & keeping below 65 mph).
Old May 4, 2024 | 08:34 AM
  #43
scraprat's Avatar
scraprat
Top Answer: 5
Blasphemy...some will have no part of neutering a 4.30 pulling power machine. If mileage is end goal a Prius and pup tent are in order.
Old May 4, 2024 | 09:32 AM
  #44
GAZZILLA's Avatar
GAZZILLA
You forgot the Birkenstocks and rainbow colored tie-dye tank top.
Old May 4, 2024 | 09:35 AM
  #45
techrep's Avatar
techrep
and a propeller wheel beanie hat...
