Reverse beeping warning
Old May 3, 2024 | 09:04 PM
Member No. 1's Avatar
Member No. 1
Rather Be Rid'n!
Originally Posted by ptnaps
Thanks for all the info. I got it with the reverse beeping because it's also used as a work truck, however I didn't take into account when I'm hooking up my trailers late at night that it would be such a problem. I was hoping for more of a solution of just switching it on and off from inside the cab somehow.
If you want the option of turning it on or off from inside the cab, you could run a 2 wire cable from the alarm to the cab, tie into the ground side of the alarm, then connect to a switch mounted in the cab.
These are basic instructions assuming you are comfy with wiring. If you need more detailed instructions PM me.
Old May 3, 2024 | 09:05 PM
Member No. 1
Rather Be Rid'n!
Originally Posted by 4wd6.7L
I bet someone with some basic electrical knowledge could figure out how to make it switched.
I know a guy! 😉🤣
Old May 6, 2024 | 01:28 PM
camperfanatic01's Avatar
camperfanatic01
add a relay and use an upfitter switch if you have them.
asterof
1997 - 2003 F150
Nov 12, 2023 02:50 PM
94yj
Mar 21, 2022 08:47 PM
Frank79
Jun 18, 2021 05:40 PM
Rockafella
Feb 15, 2003 09:09 PM
