Reverse beeping warning
Old May 1, 2024 | 08:38 PM
ptnaps's Avatar
ptnaps
Trailering
Is there a way to turn off the reverse beeping sound on a 2024 f350?
I ordered it with the beeping, so it turns on when I go I to reverse. it's more annoying and loud then it is useful so I want to be able to turn it off now or just disconnect it totally.
Old May 1, 2024 | 08:45 PM
Phillbo's Avatar
Phillbo
You know, I 've only heard it a couple times on my truck. Both times was when I was reversing rather quickly for a distance. After that, never again.
Old May 1, 2024 | 08:46 PM
4wd6.7L's Avatar
4wd6.7L
Is it beeping everytime you put it in reverse or only when close to other objects?
Old May 1, 2024 | 08:47 PM
Ltngdrvr's Avatar
Ltngdrvr
Top Answer: 5
Does your truck have a backup alarm, or is it the reverse sensors sounding off because something is behind you???
Old May 1, 2024 | 09:04 PM
ptnaps's Avatar
ptnaps
Trailering
I ordered it with the reverse beeping alarm so it goes off as soon as I put it into reverse, it's more annoying than useful and at night it's very loud for the neighbors. is there an easy way to disconnect it?
Old May 1, 2024 | 09:15 PM
4wd6.7L's Avatar
4wd6.7L
In past threads I've read that it can be unplugged under the truck. If you go that route it would be a good idea to somehow seal the connectors from the elements.
Old May 1, 2024 | 09:39 PM
Ltngdrvr's Avatar
Ltngdrvr
Top Answer: 5
It's supposed to be loud and annoying!
Why did you order it?
Yes, I'm sure it can be removed or unplugged under the back of the truck.
Old May 1, 2024 | 09:47 PM
1olddogtwo's Avatar
1olddogtwo
Probably will cause a check engine light..... LoL
Old May 1, 2024 | 09:51 PM
Ltngdrvr's Avatar
Ltngdrvr
Top Answer: 5
Maybe, but not a CEL, a screen message maybe, worth a try.
Old May 2, 2024 | 06:53 AM
Member No. 1's Avatar
Member No. 1
Rather Be Rid'n!
Sell it to this guy! LOL
https://www.ford-trucks.com/forums/1...kup-alarm.html
Old May 2, 2024 | 07:03 AM
zeroo's Avatar
zeroo
One of my builders lariat came with it, dumbest thing ever. I unplugged it for him with no issues.
Old May 2, 2024 | 09:45 AM
99powerstrokedF250's Avatar
99powerstrokedF250
I could see having it if it was a work/business vehicle, a LOT of those are required to have reverse alarms over a certain GVW I think (look at all the box trucks and panel vans that have them). Maybe it's just a recommendation, I'm not sure, but there are a LOT of business vehicles out there that have them. For my own personal vehicle I wouldn't even bother with it.
As said above, you should be able to just unplug it, though I'd consider sealing off the connectors, even a heavy-duty rubber balloon and a zip tie would work (done this on RC cars to protect transmitters from mud/water) temporarily. If you have ForSCAN you might be able to program it out without disconnecting anything.
Old May 2, 2024 | 10:38 AM
zeroo's Avatar
zeroo
First thing any of my equipment or trucks(if equipped) is get the alarm unhooked. Most every sub I work around does too. If you have to go to one of those commercial jobs that requires them then plug it back in.
Old May 3, 2024 | 08:57 PM
ptnaps's Avatar
ptnaps
Trailering
Thanks for all the info. I got it with the reverse beeping because it's also used as a work truck, however I didn't take into account when I'm hooking up my trailers late at night that it would be such a problem. I was hoping for more of a solution of just switching it on and off from inside the cab somehow.
Old May 3, 2024 | 09:01 PM
4wd6.7L's Avatar
4wd6.7L
I bet someone with some basic electrical knowledge could figure out how to make it switched.
