86 brake proportion valve reset
Old May 1, 2024 | 12:39 PM
86EFI5.0's Avatar
86EFI5.0
Is it possible to reset the stock proportion vavle. new rear brake lines and hardware. barely getting any fluid to the rear wheels?
Old May 1, 2024 | 02:26 PM
Max Capacity's Avatar
Max Capacity
Will this help
https://www.google.com/search?q=is+i...t=gws-wiz-serp
Hopefully one of the experts will chime in soon.
Old May 1, 2024 | 02:27 PM
Max Capacity
How to reset brake proportioning valve f150?
Press the brake pedal three times, with even, gentle pressure, until the pedal is applied as far as it can go. That should recenter the valve and your proportioning valve reset will be complete. If the valve still does not reset, open one bleeder on the side of the valve that IS getting brake fluid.
Old May 1, 2024 | 05:32 PM
Franklin2's Avatar
Franklin2
The only thing you are doing when you reset the proportioning valve is getting the brake light to turn off. It will not restrict the fluid. Unless it's clogged with rust.
Old May 2, 2024 | 07:31 AM
Max Capacity
Thanks for that, I was wondering about why he would want to do that.
OriginalDylan2
Jul 19, 2021 02:42 PM
jetfiremuck
Aerostar
Sep 27, 2014 05:13 PM
curtisbutlerjr
Jun 17, 2014 02:18 PM
Fluky
Feb 22, 2007 06:26 PM
Chris Nikirk
Oct 2, 2004 01:52 AM
