Code 327
Old Apr 30, 2024 | 07:15 PM
peteinstem's Avatar
peteinstem
3rd Gear
Code 327
I have a 1993 F150 5.8 4x4 e4od. Picked this truck up non running working through codes. It now runs sometimes good and most of the time rough. The last code I’m working on is 327. This code is KOEO. I replaced the egr and the evp. I put a meter on the evp and this is what I got with engine operating temp when it was cold ohms were a little lower.
Voltage Refrence 5.02 volts
VREF and EVP 4928 ohms
SIG RTN and EVP 625 ohms
From what I read these numbers are ok
What am I missing or where do I go next?
Thanks
Old Apr 30, 2024 | 09:01 PM
Junktownbill99's Avatar
Junktownbill99
327- EGR feedback signal is/was low – EVR or PFE
Test your EVR (EGR Valve Regulator)
Old May 1, 2024 | 07:27 AM
manicmechanic007's Avatar
manicmechanic007
The pinpoint tests have you checking voltage, not resistance.
I would run through the actual pinpoint tests for your code 327 in the PCED
Old May 1, 2024 | 09:40 AM
peteinstem's Avatar
peteinstem
3rd Gear
I switched out ecu with another truck I have and now it runs great. Thank you for the suggestions.
modular2v
Feb 12, 2011 10:33 AM
dixokai
Nov 28, 2007 01:06 PM
pikiluvi
Mar 6, 2007 06:54 PM
cablemaster
Sep 20, 2004 05:24 PM
hawkint
Sep 7, 2000 01:28 AM
