Spark Plug Wire ?
Old Apr 29, 2024 | 09:20 PM
BBF4's Avatar
BBF4
Spark Plug Wire ?
I just installed a 6 volt positive ground Pertronix electronic ignition on my truck. I know if I don't install suppressed plug wires instead of solid core wires I will end up damaging my Pertronix (I made this mistake on an antique tractor). The wires look newer and more modern, but none of the wires say if they are suppressed or not. Is there a test I can perform on the wires with a multimeter to see if they are solid core or not?
Old Apr 29, 2024 | 10:23 PM
EffieTrucker's Avatar
EffieTrucker
Phantom of the Phorum
You might be able to pull a plug wire from the distributor and look at the connection with the clip. You might be able to see the fiber or metal core wire.
Old Apr 30, 2024 | 10:24 AM
Carbonarc's Avatar
Carbonarc
An easy test is to check the resistance with an Ohm meter. Near zero ohms indicates solid core wire. Suppressed wire has a much higher restance: a few hundred ohms per foot or more.
joey2fords
May 15, 2013 10:22 PM
cbass139
Jul 21, 2009 11:16 AM
Mudder
General Automotive Discussion
Aug 16, 2005 07:27 PM
txzaphod
Aerostar
Sep 15, 2004 12:28 PM
ibuzzard
Feb 2, 2004 07:38 PM
