spark plug wires
Old May 15, 2013 | 09:30 PM
joey2fords's Avatar
joey2fords
spark plug wires
my 1989 4.9litre was running poorly ... missing all over the place; not fun to drive. finally got around to doing a basic tune-up on it and, to my surprise, it runs perfectly now. who knew that basic maintenance was so important ?
however, while removing the spark plug wires, 2 of them broke (i guess that's why they say to be careful when removing them ). the ones i had in there were 8mm and i replaced them with a couple of 7mm that i had lying around. should i be worried about frying my engines electronics ?
Old May 15, 2013 | 10:22 PM
GoinBoarding's Avatar
GoinBoarding
They broke? If the wire tugged off the boot, look in the boot. You'll see a little screw down inside. Push the wire back into the boot and twist so the wire threads onto the screw. Now stop tugging on the wires and just pull on the boot!
If anything actually broke, your wires are probably semi rotten and ought to be replaced.
As for the 7mm wires, I don't foresee an issue in hurting anything. Probably just have a little less current through the plugs with the smaller wires, so a little smaller spark, due to the slight increase in resistance of the wire.
Glad its running well for you again
ssg1957
Feb 22, 2015 10:19 PM
SoCar72
Jul 25, 2011 08:41 PM
460GasMeister
Mar 24, 2011 07:41 PM
Mudder
General Automotive Discussion
Aug 16, 2005 07:27 PM
jonney_boy
1997 - 2003 F150
Nov 15, 2003 08:28 AM
