Recommendations For U0601 Code?
Old Apr 29, 2024 | 11:50 AM
b.h.riggs21's Avatar
b.h.riggs21
2nd Gear
Hello all! Hoping to get some ideas on how I can fix my truck that has the check engine light on with code U0601 (Lost Communication with Particulate Filter Pressure Sensor "A"). I have a 2021 F-450. I have looked at the truck and the sensor is plugged in, wondering if it is a sensor replacement? Hopefully not the filter itself as I saw those are expensive! I've tried google and youtube and just not having luck figuring out how to best diagnose this code. Would appreciate any insight! Thank you in advance! Ben
Old Apr 29, 2024 | 11:55 AM
redford's Avatar
redford
FTE Leadership Emeritus
Well, the simple answer is that the sensor is bad, or the wiring to the sensor is messed up.
Old Apr 29, 2024 | 11:57 AM
4wd6.7L's Avatar
4wd6.7L
How many miles on the truck?
Old Apr 29, 2024 | 11:58 AM
b.h.riggs21
2nd Gear
102,500ish.
Old Apr 29, 2024 | 12:02 PM
4wd6.7L's Avatar
4wd6.7L
Originally Posted by b.h.riggs21
102,500ish.
Ok, so well outside of warranty. Have you unplugged the connection to see how it looks inside? Maybe that and try to follow the wires back to see if there is any obvious damage.
Old Apr 29, 2024 | 12:04 PM
Ltngdrvr's Avatar
Ltngdrvr
Top Answer: 5
Yeah, lost comm with sensor means it is not getting a signal to the pcm, so most likely a harness or harness connector issue.
Gwilkrrs
Jun 2, 2023 05:59 AM
Gwilkrrs
Mar 21, 2023 04:58 AM
Gwilkrrs
Jun 17, 2022 08:28 AM
air1jpg
2004 - 2008 F150
Feb 19, 2014 09:22 PM
grndpndr2
6.4L Power Stroke Diesel
Dec 2, 2010 12:35 PM
