Nox sensor code P2200
Old Jun 1, 2023 | 05:45 AM
Gwilkrrs's Avatar
Gwilkrrs
2017 6.7 with 125k. drove for awhile with check engine light on and code p2200. replaced the front nox sensor a bit ago. cleared codes and 10 miles later same code and light came on. cleared again and it lasted a bit longer but came back on. i have a cheaper handheld scanner, would a mechanics scanner tell me more or better where/what my problem is since i dont think its the nox sensor since i replaced it?
code p2200 = Nox sensor circuit Bank 1 sensor 1
Old Jun 1, 2023 | 07:48 AM
Ltngdrvr's Avatar
Ltngdrvr
Top Answer: 5
Possible harness or harness connector issue,
https://www.obd-codes.com/p2200
Old Jun 1, 2023 | 01:57 PM
Gwilkrrs's Avatar
Gwilkrrs
thanks=
i suppose i will look into that then and try to trace it out.
Old Jun 1, 2023 | 05:34 PM
Power_Stroking's Avatar
Power_Stroking
Check the fuse for that nox sensor in your bjb. I don’t remember that exact fuse number but I believe it’s a 20 amp. Also check the connector for water intrusion, there’s a tsb for that connector and the other associated connectors taking on water. Service pigtails are available now though so no need for the whole harness. A lot of times I’ve been finding the heating element in the sensor shorts to the body of the sensor and blows the fuse.
Old Jun 1, 2023 | 07:49 PM
Gwilkrrs's Avatar
Gwilkrrs
Well hadn’t thought about a fuse-
nor the wire connector/harness
thanks
weekend sleuth work……
Old Jun 2, 2023 | 05:59 AM
Power_Stroking
thanks
thinking about the fuse I believe it powers some other things as well so it may not be that. I do no that connector is a bit of a pita to get seated sometimes though.
Gwilkrrs
Mar 21, 2023 04:58 AM
Gwilkrrs
Jun 17, 2022 08:28 AM
J.millez
6.7L Power Stroke Diesel
Jun 5, 2022 05:04 PM
air1jpg
2004 - 2008 F150
Feb 19, 2014 09:22 PM
Mulletwagon
Oct 6, 2001 08:23 PM
