Question about injector o rings
Old Apr 28, 2024 | 08:20 PM
koy's Avatar
koy
Trailering
Hello all, I have a question concerning leaking injector o rings.
I have recently replaced the o rings on all 8 injectors with o rings from riffraff diesel because some were leaking oil into the head, 7 of 8 injectors no longer leak oil, but 1 is still leaking even with new o rings. So I pulled the leaky injector back out thinking I may have installed the o rings incorrectly, but everything looks fine. So now I’m thinking the next thing to do would be to move that injector to a different cylinder to see if the leak follows the injector. Is this ok to do? (Don’t know if injectors like to stay with the same cylinder.) Or is there another way I should proceed? Thanks in advance for any suggestions.
Old Apr 29, 2024 | 02:20 PM
knottyrope's Avatar
knottyrope
yes is ok to move an injector, mark it prior so you know later
killthe6.0forddiesel
13
Jan 25, 2026 04:46 PM
kpjr
30
Aug 18, 2011 08:12 PM
Farmboypowerstroke
Jul 19, 2011 01:52 PM
ltl_jrw
Jun 27, 2011 11:29 PM
roadbike21
Oct 27, 2006 05:52 PM
