Help ID 9 inch axle
Old Apr 28, 2024 | 01:13 PM
Lumpy70's Avatar
Lumpy70
1st Gear
Help ID 9 inch axle
Hey all, I joined because maybe you experts could help me out identifying the year / model of my Ford 9" that was shoved in my Frankenstein 1963 Toyota Landcruiser, since the identification tag is missing. Not much on the outside of the diff, see picture links: https://photos.app.goo.gl/bdz7Jdoi5J1PjEw39
It was a welded diff and I want an open diff for street driving, but can't find the right parts because I can't identify it. I already bought one wrong open carrier from ebay.
The ring says this:1 SA-D27W 4210 B 937, which could be 'B' for 4.2, 10", February '93...but I don't think that's right since it's a 9" and was out of production by the mid-80?
The outside of the diff says WAR B 4025 , and the INSIDE says 96E and 4224.
Any help would be appreciated,
Thanks.
Craig
It IS a 28-spline 4.10
Old Apr 28, 2024 | 04:12 PM
85e150's Avatar
85e150
I moved you here away from that old mess of a hijacked thread you were on.
Old Apr 28, 2024 | 04:34 PM
charlie g's Avatar
charlie g
FTE Community Team
welcome to this site
hard to tell truly what you have with all the rubgoldberging on the rear, main case wise most 9.0's are the same, the diffs themselves defer a lot , by gear ratio axle 28/31/35 spline count .
real world not knowing just what you have you might be better off buying a assembled center section with what you want in it along with a custom housing that bolts in safer than how i see it secured on the left with that u bolt
good luck man
Old May 2, 2024 | 09:04 AM
DaveMcLain's Avatar
DaveMcLain
That's an aftermarket spool not anything that's been modified. Get a spline count on the axles that are in it and then find the differential of your choice to fit that number of splines. This could be an open, a Detroit locker, a torsen, you name it. There are lots of options. As far as I know production 9 inch differentials all used the same size where the carrier bearing goes onto the differential but there are variations in the carrier bearings themselves mostly due to differences in the housings bore diameters. Careful work with the press and you might be able to just remove the carrier bearings from your spool and put them onto a different differential. A WAR case is a very old 9 inch case that looks sort of like a nodular iron but isn't. Still should be fine for your application.
Old May 2, 2024 | 02:50 PM
charlie g's Avatar
charlie g
FTE Community Team
i was looking at that pinion angle, NOT GOOD, the pinion gear bearing set is being starved with all the oil to the back of the housing, war rear i'll bet it's a 28 spline axle not the strongest ford ever made
nairod
Dec 23, 2021 11:20 PM
shane1963
13
Jul 29, 2011 10:45 AM
velcro7279
Apr 21, 2008 02:13 PM
19felix69
Jan 1, 2005 10:43 PM
78 Swamp Donkey
Mar 3, 2003 11:01 PM
