limited or posi?
Old Jul 28, 2011 | 09:20 AM
shane1963's Avatar
shane1963
limited or posi?
hi ,im changing the rearend in my 94 f150 4x4,the old tag on the original diff says, S838F, 3 55 88 3L17,the tag on the new diff says, 28O7D, 355 88 9D19.my question is,does the letter D mean i have positrac? thnx for any help.
Old Jul 28, 2011 | 10:02 AM
Diesel_Brad's Avatar
Diesel_Brad
Your "old" axle tags states that you have an open 3:55 gear axle w it saying 3 55
The "new" axle tag states the same thing. Just an OPEN axle.
in order to have Limited slip, it must say 3L55
Old Jul 28, 2011 | 12:43 PM
Edgethis's Avatar
Edgethis
That just means it came from the factory as an open diff. Best way to be sure is pop the cover off and look, or spin the wheel and see what the other does.
Old Jul 28, 2011 | 01:13 PM
shane1963's Avatar
shane1963
ok thnx guys,now the reason im changing rearends is because diff had no oil in it and caused damage.now would it be easier to change just the differential instead of the whole rear end and would the differential guts with tag number 355889D19 take place of the guts from the original rearend with tag number 355883L17,lol guess what im trying to say is that im thinking is taking the back plate off both and exchanging the guts (diff)instead of the whole rearend,anyone know if this will work?will the D19 fit into the L17 housing,thnx again.
Old Jul 28, 2011 | 01:23 PM
Edgethis's Avatar
Edgethis
Should but I think you may need to change pinion too if you do that.
Old Jul 28, 2011 | 01:29 PM
dclack's Avatar
dclack
Are you sure about the tag on the new diff? 28O7D doesn't make since. If it's S807D, then it is a LS 3.55 diff. Ford Axle Identification
Old Jul 28, 2011 | 01:34 PM
dclack's Avatar
dclack
The ring and pinion gears are machined together, don't mix and match them. If you want to swap the guts you need to change the pinion as well. If you have the whole axle, it would be easier to swap the whole thing than setting up gears.
Old Jul 28, 2011 | 01:35 PM
shane1963's Avatar
shane1963
oops your right dclack,it is an s not a 2. s807D
Old Jul 28, 2011 | 02:11 PM
andym's Avatar
andym
I would just swap the whole axle rather than risk having to set the gears up again.
Old Jul 28, 2011 | 08:20 PM
shane1963's Avatar
shane1963
well put the new rearend on stands and had to knock pry etc the drums off as they were stuck. anyway when i turn one side,the other side spins the same way and when i spin backwards the other side spins backwards too.does this mean its posi?
Old Jul 28, 2011 | 08:24 PM
shane1963's Avatar
shane1963
also i noticed i can move the axels in and out about a 16th of an inch on both sides is this normal play?when i try twisting sideways or up and down,its solid.thnx
Old Jul 28, 2011 | 09:14 PM
str8sixman's Avatar
str8sixman
If both wheels turn the same way then its limited slip....and as far as the axle movement that's perfectly normal. A characteristic of a c clip axle
Old Jul 28, 2011 | 09:41 PM
shane1963's Avatar
shane1963
thnx str8sixman,kinda sucks but oh well,lol. the guy that sold it to me told me it was a positrac,only cost 100 bucks though,thnx again.
Old Jul 29, 2011 | 10:45 AM
andym's Avatar
andym
You should have known he didn't know what he was talking about when he used the term 'posi' on a Ford axle.
joegeds
Oct 5, 2014 09:23 AM
bigdaddyII
2004 - 2008 F150
Jan 23, 2012 05:47 PM
George84
Nov 4, 2010 05:06 AM
mikeberman04
1978 - 1996 Big Bronco
Apr 26, 2008 07:08 PM
dunedevil69
1997 - 2003 F150
Oct 18, 2003 05:17 PM
