Engine cuts out/tach drops
Old Apr 27, 2024 | 03:40 PM
Crutters's Avatar
Crutters
2nd Gear
Hi! I'm new here but not to trucks.
My son has a 1990 F150 with a 5.0.
Does anyone have any experience with an engine cut out at idle and or light throttle?
No engine light, fresh tune up and fresh igntion module.
Old Apr 28, 2024 | 05:21 AM
manicmechanic007's Avatar
manicmechanic007
Yes, most of us have
The capacitors in the processor need to be checked
You should check the EEC 4 codes in case that can send you in a correct direction
Codes like 15 and 18 are processor related
You could try running it around with the spout plug out
Could be a lean issue, a bad injector, just about anything
The process of elimination is your friend
You can do an old fashioned cylinder balance test
Pull each plug wire off at idle one at a time and verify the RPM drop
Things like that help
You said tune up. Did you replace the wires and the cap and rotor?
Old Apr 28, 2024 | 01:22 PM
Prototypemech's Avatar
Prototypemech
Do any of your other gauges instantly flicker when the engine cut out?
Yes=ignition switch on top the steering column is failing.
No=Profile ignition pickup sensor inside the distributor is failing... Or
Ignition control module is failing.
Does it happen when the engine i warm or at all times?
Old Apr 28, 2024 | 04:02 PM
Crutters's Avatar
Crutters
2nd Gear
Just the Tach drops.
It's definitely not a single cylinder misfire.
The ignition module was just replaced for other symptoms. I was thinking about ignition primary, the truck has been sitting for a few years.
mechelement
Aug 25, 2010 10:35 PM
fordracer90
Apr 9, 2009 05:54 PM
Chris9292
Mar 17, 2008 08:45 PM
SmurfF250
Nov 16, 2006 01:42 PM
poknox
May 10, 2004 08:33 PM
