Tachometer problems
Old Mar 16, 2008 | 08:40 AM
Chris9292's Avatar
Chris9292
Tachometer problems
I have an intermittent tachometer problem on 92 F-150 5.0 that is causing a chk eng light. Is the tach receiving info from the coil?
Old Mar 16, 2008 | 09:37 AM
fmr9's Avatar
fmr9
Tach causing check engine light?
Never heard of this.
More likely you have a problem causing a check engine light, and maybe seeing a result in the tach.
What codes are present?
Frank
Old Mar 16, 2008 | 05:20 PM
Chris9292's Avatar
Chris9292
Have a code 13, Can't control low idle. New idle motor is running idle correctly, but not showing on tach. Tack won't go below 2500. Doesn't move through full range, with key on and not running, goes to 5000.
Old Mar 17, 2008 | 08:45 PM
Chris9292's Avatar
Chris9292
Anyone have a wiring diagram that might help with this tach problem?
Toplait
Jun 8, 2012 08:36 PM
banjopicker66
Mar 25, 2010 09:29 AM
musickerns
1997 - 2003 F150
Dec 18, 2009 02:36 PM
fiddler5.0
Jun 30, 2005 10:13 AM
josh3972
Bronco II
Oct 13, 2001 11:02 AM
