battery light and voltage drop occasionally
Old Apr 25, 2024 | 11:38 PM
Kemicalburns's Avatar
Kemicalburns
I couple years ago i installed a 140amp alternator inplace of the 110amp alt. My batteries are 2 yrs old (Motorcraft) and occasionally when its been below 50 degrees outside i see my battery light flickering and my scan gauge shows 11.9-12.5 volts. it seems this continues till the engine gets up to about 120-140 degrees and is back to normal.
would this be a sign of bad battery wires, alt harness, alternator or batteries?
Truck has 170k miles on it.
I appreciate your feedback and suggestions
Old Apr 25, 2024 | 11:53 PM
BLADE35's Avatar
BLADE35
Normally a sign of bad alternator with that light doing the flickering
But you will want to clean inspect cables and have batteries load test
there is a Ford alternator pinpoint test
it was more accurate then having a parts store test the alternator on there machine (kids working have to many pulley options when hooking it up they spin it to fast what then shows good part when it really not good at lower rpm)
someone should be along with the alternator pinpoint test my PC is down at the moment
Old May 2, 2024 | 09:39 AM
Kemicalburns
I just looked back when I purchased this Alternator and its 6yrs old. anyone know if the Bosch AL7606N can be rebuilt?
Old May 2, 2024 | 10:20 AM
TooManyToys.'s Avatar
TooManyToys.
Typically, they need a new voltage regulator, and they are easily rebuilt.
Old May 2, 2024 | 10:36 AM
TooManyToys.
But that alternator has a lifetime warranty ......
Old May 2, 2024 | 01:42 PM
Kemicalburns
I bought this thru Amazon, they are such a pain to deal with regarding lifetime warranty replacement.
Old May 2, 2024 | 02:12 PM
TooManyToys.
Lately, it seemed like others were able to do it.
If you want to try a voltage regulator change, I think you need an F600HD. But I have not tried it.
To change it, I made a video about clocking or changing the VR. I used AI for the voice for the video, as mine was in bad shape.
Imogearguy
Nov 18, 2023 08:42 AM
bigcountry1009
Oct 3, 2022 04:27 PM
andym
May 19, 2015 07:37 PM
medic25
Dec 10, 2012 02:20 PM
noel431
2004 - 2008 F150
Apr 18, 2010 02:35 PM
