Front brake pads/rotor swap difficulty
Old Apr 23, 2024 | 10:43 PM
1965_Ford's Avatar
1965_Ford
I have a 65 F100 I bought from a local private seller. When I pulled off the front wheels to do a brake job they are disc instead of drum so obviously a conversion.
When I took the pads to the auto shop they had to match them in a book and it turns out they are from a 73-83 F100. They are Wagner ZX-50 and look like this.
https://www.summitracing.com/parts/wgb-zx50
My problem is stupid. I’m trying to get the pads to stay in the calipers but they keep popping out. The anti rattle clips want to spit them out and if I try to put them in without the clips they are wiggling around and just want to fall out before I tighten everything down. I’ve done many brake jobs on newer cars real quick.
Anyone have a trick? I’ll face palm myself. 🤦‍♂️
Old Apr 24, 2024 | 06:27 AM
Drivewayfabricator's Avatar
Drivewayfabricator
Pretty decent video on the subject. Piston side pad goes in the spindle first, then the pad with the bigger tabs goes in the caliper on the non piston side. Slide the caliper on, push it up, drive in the key and spring. Skip to about the half way point in the video.
chadstickpoindexter
Dec 27, 2022 06:19 AM
harley7991
Apr 10, 2022 05:41 PM
aurgathor
Aug 30, 2009 01:21 AM
John7894
Sep 8, 2006 09:50 PM
barebackjake
Jan 15, 2006 10:12 PM
