2023 6.7 check engine light
Old Apr 23, 2024 | 09:06 PM
clpaw's Avatar
clpaw
Trailering
Hopefully all of the wizards on this site can share their vast knowledge. Went to town this yesterdqy and my check engine light came on. Shut truck off in town. Headed back home light still on. Got the truck back to my shop, Got my laptop and fired up forscan. There are no DTC codes......................I am perplexed. I have been idling the truck a lot for the last two days, I am working on my gooseneck trailer lights and brakes. The only other thing I have noticed is I have smelled burnt rubber twice near the front of the vehicle, but could not narrow its source. I got the truck October 1st and it has right at 7000 miles.
I pulled the gooseneck 150 miles today, no issues but light is still on, once again no tonight dtc codes in forscan.
Old Apr 23, 2024 | 09:29 PM
Fireferg73's Avatar
Fireferg73
I see multiple code populated. You’re looking specifically at the TCM, the transmission control module. It shows a code in the PCM, p0281 which I believe is a cylinder contribution code.
It also shows codes in the BCM and PSCM(power steering control module)
Do you have any issues with any lights or heated steering wheel?
Old Apr 23, 2024 | 09:44 PM
Ltngdrvr's Avatar
Ltngdrvr
Top Answer: 5
Yup, 5 codes showing in your scan, I believe only the pcm and pscm codes will turn the check engine light on.
Old Apr 23, 2024 | 09:47 PM
Fireferg73's Avatar
Fireferg73
Can FORScan reset injector adaptation tables?
Old Apr 23, 2024 | 09:54 PM
clpaw's Avatar
clpaw
Trailering
I am a forscan novice, I assumed the first line was the result. Thanks for the input. I will try resetting tomorrow. It is strange since the truck is running great. I will go thru the codes. This does not look like a simple thing.
Old Apr 23, 2024 | 11:34 PM
Member No. 1's Avatar
Member No. 1
Rather Be Rid'n!
There are features of ForScan I’m still learning, one being CEL and trouble code reading, and I have yet to use this feature or poke around. Never had a code on anything so no need to read any.
For my info, and not to point out an oversight, but am I correct in seeing 6 not 5 codes? The last one on the bottom is cut in half.
Old Apr 24, 2024 | 10:27 AM
clpaw's Avatar
clpaw
Trailering
I reset the dtc codes with my laptop and forscan program and it has cleared the check engine light. With the engine running, here are the latest dtc codes.
Here is what I found online. The most common symptom of this code is an activated check engine light. But sometimes you may not have any warning lights or you may have warning lights you don’t recognize, depending on the year model of the vehicle. U0100 code symptoms range from no symptom at all to a possibility that your vehicle will not be able to start or that the starter may not even engage. Once this happens, it is recommended to have your vehicle checked right away for proper diagnosis.
This does not look good.
Old Apr 25, 2024 | 12:27 PM
Ford Motor Company's Avatar
Ford Motor Company
Official Ford Pro Rep
Good afternoon! Feel free to send over a DM with your vehicle's VIN and mileage. We'd like to look into your truck concern.
gcardwell2
2015 - 2020 F150
Oct 12, 2022 09:10 AM
Gwilkrrs
Jan 21, 2022 08:26 AM
gdiehl
6.7L Power Stroke Diesel
Oct 28, 2021 11:44 PM
tenptbuck7mmmag
1997 - 2003 F150
May 6, 2008 10:18 PM
rustee90-150
Nov 11, 2007 05:03 PM
