‘97 460 idle too high ? Rough.
Old Apr 26, 2024 | 10:16 AM
Bruce51's Avatar
Bruce51
Have you checked the timing with the spout pulled? It should be 10 BTDC. It may be past time to change your plug wires. Mine ran so much smoother after I changed the wires.
Bruce
Old Apr 26, 2024 | 12:35 PM
Junktownbill99's Avatar
Junktownbill99
Originally Posted by longwhitexl
I don’t think 900 is abnormally high for these trucks. Mine has always idled around 700-900. I wish it was closer to 500-600
My 5.0 idles 650, pretty sure the 5.8 is the same at 650-850
Old Apr 27, 2024 | 07:50 AM
Ironhorse2022's Avatar
Ironhorse2022
Thanks for the input on plug wires - I was thinking about that. I did sandpaper the contacts inside the distributor cap to clean them up. Pretty oxidized so probably the orig cap (and wires). Yes, I’m used to the idle being around 650. I haven’t purchased a service manual for the truck yet so don’t know what it’s supposed to be.
Old Apr 27, 2024 | 11:44 AM
Junktownbill99
I have a new theory, the engine should idle at 650 when warm, it tends to idle around 800-900 when still cold.
I'm beginning to suspect your ECT sensor isn't functioning properly. This may explain the rough idle, as it may actually be running rich, thinking the engine is colder than it actually is.
Patdietz
Oct 19, 2023 09:10 AM
99f350cclb
Dec 8, 2021 10:24 AM
JosephDunivan
Aug 28, 2015 11:12 PM
Diesel Mechanic 08
13
Feb 9, 2010 01:56 PM
Black Smoke '88
Dec 13, 2009 07:03 PM
