‘97 460 idle too high ? Rough.
Old 04-26-2024, 10:16 AM
Bruce51's Avatar
Bruce51
Bruce51 is offline
Trailering
Have you checked the timing with the spout pulled? It should be 10 BTDC. It may be past time to change your plug wires. Mine ran so much smoother after I changed the wires.
Bruce
Old 04-26-2024, 12:35 PM
Junktownbill99's Avatar
Junktownbill99
Junktownbill99 is online now
Originally Posted by longwhitexl
I don’t think 900 is abnormally high for these trucks. Mine has always idled around 700-900. I wish it was closer to 500-600
My 5.0 idles 650, pretty sure the 5.8 is the same at 650-850
Old 04-27-2024, 07:50 AM
Ironhorse2022's Avatar
Ironhorse2022
Ironhorse2022 is offline
Thanks for the input on plug wires - I was thinking about that. I did sandpaper the contacts inside the distributor cap to clean them up. Pretty oxidized so probably the orig cap (and wires). Yes, I’m used to the idle being around 650. I haven’t purchased a service manual for the truck yet so don’t know what it’s supposed to be.
Old 04-27-2024, 11:44 AM
Junktownbill99
I have a new theory, the engine should idle at 650 when warm, it tends to idle around 800-900 when still cold.
I'm beginning to suspect your ECT sensor isn't functioning properly. This may explain the rough idle, as it may actually be running rich, thinking the engine is colder than it actually is.
Patdietz
10-19-2023 09:10 AM
99f350cclb
1999 to 2016 Super Duty
12-08-2021 10:24 AM
JosephDunivan
08-28-2015 11:12 PM
Diesel Mechanic 08
13
02-09-2010 01:56 PM
Black Smoke '88
12-13-2009 07:03 PM
Quick Reply: ‘97 460 idle too high ? Rough.
