DTE not resetting
Old Apr 23, 2024 | 04:43 PM
Reverend Jim's Avatar
Reverend Jim
Veteran: Navy
DTE not resetting
My DTE, (distance to empty), above the fuel gauge does not reset occasionally after I fill the tank. Sometimes it will stay at whatever the value was prior to refilling and then start counting down normally when the gauge reads what it was prior to the fill up, other times it will slowly count up a few miles over several days. I've noticed it mostly after I come out of tow mode. I searched and couldn't find anything like it. Any thoughts on why this happens? Any way to force a reset? I already tried resetting the mpg display in the menu with no effect. T.I.A. for any help.
Old Apr 23, 2024 | 11:58 PM
RV67's Avatar
RV67
8th Gear
Try Battery disconnect for half hour might reset
Old Apr 24, 2024 | 12:34 AM
4wd6.7L's Avatar
4wd6.7L
I can't say that I've ever seen that happen in mine. It always has a different (higher) DTE on start up after fill up. Not sure what would cause that delay.
Old Apr 24, 2024 | 10:32 AM
Reverend Jim
Veteran: Navy
@RV67, I tried your suggestion- disconnected both batteries for 30 minutes. No change.
Old Apr 24, 2024 | 11:48 AM
Ford Motor Company's Avatar
Ford Motor Company
Official Ford Pro Rep
Hi there. We'd like to look into getting you assistance with your fuel gauge. Please send us a DM with your vehicle's VIN and mileage.
Old Dec 25, 2024 | 01:12 PM
Msjm55's Avatar
Msjm55
1st Gear
DTE not resetting after refueling. 2019 F350 Super Duty diesel Lariat
Any help on resetting DTE after refueling?
Old Dec 26, 2024 | 10:36 AM
Reverend Jim
Veteran: Navy
No, never did figure out what the cause was. One day it just started working again.
Old Dec 27, 2024 | 06:01 AM
Dan1954's Avatar
Dan1954
I’ve had some issues with gauges on my 2017 SD, one of which is the fuel gauge. When we go on long trips towing our 5th wheel I temporarily install a Titan 50 gallon auxiliary fuel tank. I have an activation button on the dash that when pressed will pump 5 gallons into the factory tank. When I do this the factory fuel gauge does not change to show revised DTE for about an hour. It gets a little hairy when fuel is running low in both tanks & you’re trying to find a truck stop in remote areas. I received a helpful response from this forum when I was told to try to run 20 gallons or so at a time. When I pressed the fill button three times the DTE changed within a few minutes. Probably not the same issue but does your issue happen when you do a 15 gallon or more fill up?
Old Dec 27, 2024 | 07:40 PM
dieseldrew's Avatar
dieseldrew
Another question, do you leave the engine running when you fill up or the key on ? This has an effect on how the information reads, whether it be very slowly (key on or engine running) or almost instantaneously when both shut off.
traveldawg
Oct 14, 2022 08:31 AM
blk17250
Sep 5, 2019 09:59 AM
loftygoals
6.2L V8
Mar 16, 2016 09:07 PM
diesel_hillbilly
Dec 8, 2011 07:59 PM
GeneralC.
Apr 4, 2007 12:32 PM
