DEF Usage.
Old Oct 8, 2022 | 08:35 PM
traveldawg's Avatar
traveldawg
DEF Usage.
I had another thread here about my DEF gauge acting funny - dropping from 1/2 to about 1/8th all at once. And when I filled it up at a truck stop it only took 4 gallons. After that the Maintenance Screen DEF Level said full with 9500 miles to empty.
I took it in for service, they did some kind of software update and when I got it back the screen still read full but the miles to empty was 7500.
I've since driven 1200 miles and the DEF gauge is still at 100%. Although on the Maintenance Screen DEF Level the miles to go is down to about 3000 miles.
Is this right? Seems to me that the first tank full went only about 2100 miles and now I'm more than half of that an show no usage.
(btw.... there are 2 DEF level displays - one is the Gauge View; the other is from a Maintenance Screen that allows you to also see the DEF level.
Old Oct 9, 2022 | 11:09 AM
acdii's Avatar
acdii
Yep. Mine still reads full but is actually 80%. It does not have a float in it like a fuel tank and I think goes by weight of fluid instead. It does measure how much is used to determine how much is left, and if you use an iDash, there are settings you can use to monitor DEF.
Old Oct 9, 2022 | 11:25 AM
Ltngdrvr's Avatar
Ltngdrvr
Top Answer: 5
There is about 1.5 gallons of DEF in the tank ABOVE what the gauge shows when clear full, so it will read full 100% for quite a while before the gauge starts to drop if you have completely filled it at the pump.
Also, the gauge movement is not linear, it moves quicker at some points as it drops than at other points, it is more of a loose guide than it is a precision gauge.
These truck used to not have a gauge at all, just a warning message as the tank got close to empty.
DEF usage goes up with load just like fuel usage, DEF usage is USUALLY about 2% to 3% of fuel usage, so the miles to empty varies according to use.
So, don't look at the DEF gauge as anything other than part of the reminder system.
Old Oct 9, 2022 | 06:27 PM
traveldawg's Avatar
traveldawg
That sounds reasonable - that I overfilled the tank and it just took a long time to start registering usage on the gauge. Today it finally got down to about 92% as indicated on my Forescan app and the dash gauges started show less than full. Thanks for info.
Now to continue monitoring to see if it is somewhat linear as it goes to empty.
Old Oct 9, 2022 | 07:33 PM
Ltngdrvr's Avatar
Ltngdrvr
Top Answer: 5
Why would you call it overfilled?
The only time filling it all the way to the top could be an issue is if the temps get down to the freezing point of the DEF, 11*, then being filled all the way to the top could cause cracking of the filler lines.
I fill mine all the way to the top every time I fill at the truck stop pumps, but then I use it very quickly so no chance of freeze damage.
Old Oct 10, 2022 | 08:47 PM
traveldawg's Avatar
traveldawg
The gauge continues to slowly go down. So I will go with the theory that I put so much in that I "overfilled" it - filled it above what would be normal as Ltngdrvr suggested.
Old Oct 11, 2022 | 05:26 AM
senix's Avatar
senix
a little over 600 miles per gallon of def for me so around 4K miles per tank, Alot of towing.
Old Oct 13, 2022 | 12:14 PM
acdii's Avatar
acdii
Mine is at 87% and the gauge is showing open space now instead of full. The iDash shows percentage.
Old Oct 13, 2022 | 07:50 PM
Minniehill2's Avatar
Minniehill2
My last fill was 6.4 gal of DEF.for 2000mi
or 3.2/1000
i thought this was high!!
my truck was made without an emission sensor that “will be added when available”.
could this be causing extra usage?
Old Oct 13, 2022 | 08:07 PM
Ltngdrvr's Avatar
Ltngdrvr
Top Answer: 5
or 3.2/1000
As has been discussed, DEF usage varies widely with different driving conditions.
Lower fuel economy means you will get higher DEF usage.
Old Oct 14, 2022 | 07:43 AM
speakerfritz's Avatar
speakerfritz
my def gauge has indicated 100% for the last 13000 miles.
Ive posted about this a few times.
one of the commets I get is....dont fill it until you get the blah-blah warning message...something about 50 miles warning. I counter these types of comments by saying if the def guage is always indicating full....would it ever give me the blah-blah warniing?
Old Oct 14, 2022 | 08:31 AM
Ltngdrvr's Avatar
Ltngdrvr
Top Answer: 5
If you've driven 13K miles and the gauge hasn't moved, then there is something wrong with the gauge/sensor, or you are constantly adding DEF.
llblake64
6.7L Power Stroke Diesel
16
Nov 2, 2021 06:41 AM
claf
May 19, 2021 08:55 AM
AmLS28
May 25, 2020 10:27 PM
zekes66
Oct 25, 2017 09:57 PM
mustang_gt_350
Jul 26, 2007 12:27 PM
