To much back pressure
Old Apr 23, 2024 | 01:54 AM
6.0 me's Avatar
6.0 me
3rd Gear
I have a 2005 f350 SD 6.0 I put it in a shop to have all of the fluids changed they also put a crank and a icp sensors the would not start when I picked it up. The mechanic put his scanner on it and got it started 2 miles from home it died. Since then I put 4 injectors a Hpop rebuilt the oil rail cleaned and put all new Orings in the turbo a new oem wiring harness a new ficm and here are my codes with to much back pressure that keep blowing my cac hoses off these are all PO codes 069,405,472,2104.2127,2132,2138,2139,2285 please help I have been under this hood for four months
Old Apr 23, 2024 | 01:58 AM
6.0 me's Avatar
6.0 me
3rd Gear
Let me add a new oil cooler and egr cooler new intercooler new starter
Old Apr 23, 2024 | 04:07 AM
bismic's Avatar
bismic
P2285 will happen when you try to start with an unplugged ICP.
The other codes indicate a short in the v-reference circuit. Could be the EBP sensor itself, or in the wiring somewhere.
I would start by unplugging the EBP sensor (since this test id free and easy) and see if it will start and run (you can run the truck that way for a reasonable troubleshooting distance).
If that doesn't do it, start looking for wiring damage and electrical shorts. Start by looking at the main engine harness - specifically in the area under the air intake tube.
Take pics and post them of what you find during your work looking at the harness.
Admin - can you move this thread to the 6,0L section please.
Calling @Maxium4x4
Old Apr 23, 2024 | 06:20 AM
99powerstrokedF250's Avatar
99powerstrokedF250
Sounds like you're building too much boost, not sure it's being commanded. I had that happen on my first 6.0, but mine the issue was the unison ring froze up so it was building boost 100% of the time. Your issue definitely sounds more electrical, if your mechanic pinched some wires while doing something that could be the issue.
Old Apr 23, 2024 | 07:43 AM
Maxium4x4's Avatar
Maxium4x4
Welcome to FTE 6.0 me
Old Apr 23, 2024 | 11:45 AM
6.0me's Avatar
6.0me
2nd Gear
I put a new OEM harness on it unless I damage it taking the turbo on and off so many times thinking I just was indexing it right plus I put a different compressor blade and a different exhaust blade in it and I took out each one thinking they were the problem. I have a new EBP sensor coming today. It’s funny the harness that I took out had all kinds of damage to it so many wires that had become bare and I didn’t get the codes that I’m getting now. This truck sat from 2017 until 2023 when they fixed it to sell it and I was the sucker who bought it. And I’m no diesel mechanic oh boy am I learning I now have an over the engine creeper a tire step. I’m also waiting on some other thing for the electrical that will be here tomorrow and I will give you guys an update on what I find. This time when I get it running I’m taking to a friends place and we’re pulling the cab so I can really get to some thing to check
Old Apr 26, 2024 | 07:44 PM
6.0me's Avatar
6.0me
2nd Gear
Ok let me tell you how I fixed it. New EBP sensor and a bottle of Stabilant 22 and painted every connection under my hood every connection. The stuff is expensive but when it comes to electrical connections it’s magic in a bottle.
Old Apr 26, 2024 | 08:13 PM
bismic's Avatar
bismic
Huh, imagine that .......................
Old Apr 27, 2024 | 08:57 AM
runthatjunk's Avatar
runthatjunk
Never heard of that before, looks like good stuff.
Wavynin
Apr 23, 2024 02:29 PM
ranchdweller
Aug 18, 2022 06:06 PM
mikealfano
Aug 23, 2021 07:17 PM
manley
Nov 30, 2014 12:23 AM
highsmit99
Mar 24, 2011 06:05 AM
