Power Tailgate issue
Old Apr 22, 2024 | 11:02 AM
MKrenn's Avatar
MKrenn
Went out this morning and unlocked truck with keypad. Walked to rear of truck, hit the tailgate butting twice, would not open. Tried a couple more times, no luck. Locked truck, unlocked truck, still no luck. grabbed remote, used that to open tailgate, works fine. Tried other remote, opens tailgate fine. This has got me baffled unless the push button on tailgate is faulty. Anyone ever have this happen?
Old Apr 22, 2024 | 01:39 PM
Ford Motor Company's Avatar
Ford Motor Company
Official Ford Pro Rep
Originally Posted by MKrenn
Went out this morning and unlocked truck with keypad. Walked to rear of truck, hit the tailgate butting twice, would not open. Tried a couple more times, no lick. Locked truck, unlocked truck, still no luck. grabbed remote, used that to open tailgate, works fine. Tried other remote, opens tailgate fine. This has got me baffled unless the push button on tailgate is faulty. Anyone ever have this happen?
Hi there. Feel free to send us a DM with your vehicle's VIN and mileage. We'd be happy to look into getting assistance for you.
Old Apr 22, 2024 | 01:48 PM
senix's Avatar
senix
inside the cab, does the button work?
Old Apr 22, 2024 | 01:49 PM
MKrenn's Avatar
MKrenn
Sounds good. I will PM you. Thanks
Old Apr 22, 2024 | 01:53 PM
MKrenn's Avatar
MKrenn
Hey Scott, yes that one works as well. Just not on the tailgate itself.
Old Apr 22, 2024 | 02:05 PM
senix's Avatar
senix
sounds like it is isolated to the button itself then. Must have bad contacts or maybe got wet at some point.
Old Apr 22, 2024 | 02:36 PM
4wd6.7L's Avatar
4wd6.7L
Here is a thread where the OP has the same symptoms. Unfortunately the OP didn't update with the fix (I hate that) but it includes a link to another thread with more owners experiencing the same symptoms. https://www.ford-trucks.com/forums/1...-not-open.html
Old Apr 22, 2024 | 03:41 PM
function12's Avatar
function12
I have had this happen on my 2023 F250 too. No rhyme or reason why it doesn't work some days. Dealer could not find an issue either. Good luck!
Old Apr 22, 2024 | 04:29 PM
MKrenn's Avatar
MKrenn
Read through all the other threads on this. Still did not find what they replaced. Guess i'll take the dam thing into the dealer. UGH....
Old Apr 22, 2024 | 04:35 PM
4wd6.7L's Avatar
4wd6.7L
I briefly read through two threads. I saw chaffed wires, shorted wires, loose connections being found as possible causes. Replacement of the switch looked to have been done but didn't fix the issue in some cases.
Old Apr 22, 2024 | 04:41 PM
MKrenn's Avatar
MKrenn
Yeah I seen those as well. Appreciate the comments. I may take the access plate off and take a peak inside. Will for sure update this if I find my issue.
Old Jul 23, 2024 | 11:39 AM
MKrenn's Avatar
MKrenn
Update: Got the truck into the dealer finally after 2 attempts. They found 2 wiring harnesses corroded. They said it looked like car wash detergent inside the tailgate. I asked for photos, but the tech didn't get any. I plan to seal up the access hole into the tailgate to keep that from happening again. Just thought I'd post this in case any else has this issue. Warranty covered the $690 bill.....
Speyman
Jan 25, 2024 02:36 PM
leejk
Oct 6, 2017 05:03 PM
Faceplant409
Jun 15, 2017 01:57 PM
wharrell
Feb 11, 2017 08:35 PM
TXSailor
Aug 12, 2014 11:49 AM
