Frame Damage Help
Where do you live? We might be able to find a donor if you want to change the frame out.
Have you looked the rest of the frame over really good? Rear spring brackets are also known for rusting out.
I would say if the rest of the frame is good and you cant find a full frame for replacement maybe you can find just that front part of the rail back behind the cross member.
It is work but you could then trim your frame and weld in the good one. You can use grade 8 bolts and nuts for the cross member to frame rail where the rivets were.
Might be easier to replace that part of the frame with motor removed.
Dave ----
Best would be to make a trip out of it and go south to get yourself a frame, The further south you go, the better. It's amazing to me what North Carolina trucks look like compared to the ones here in Va. My daughter lives in Pa and I know you guys have it even worse than we do.
Think F250 in 2WD would work also it would be just a little more HD but the above trucks will be 100% good to use.
You can check CL or FB market place and local junk yards.
For CL & FB look for trucks with rusted bodys, check the frames really really good dont want to buy what you got now, no motor / running gear as you can get them cheap as most of the time they just want to get rid of what they got sitting there.
All you really want is the frame, the rest once the frame swap is complete you can sell the good parts to get some money back in your pocket.
The only thing to watch out for is with frame swaps there is a VIN stamped on it and this will no longer match the VIN on the cab door sticker or windshield.
This is only an issue if you sell the truck and DMV goes looking at the VIN's or if someone goes looking for them.
If you can get the title for the good frame that helps. Vary min is a bill of sale with the new frames VIN on it.
Junk yards will know what has to be done with the VIN and they would give you a BoS.
When I gave my parts truck frame away I did not send the title or BoS with it, I forgot to, but if he reaches out I will sent it.
Dave ----
Dave ----
Tons of them in North Carolina. Reasonably priced also. Just make sure the price includes them taking the frame out from under the donor truck at the yard. Once they get it out you can look it over easily. You will also need to check for accident damage.
1986
Frame Assembly
Ford Truck F150
180 1987Frame Assembly
Ford Truck F150
180 1985Frame Assembly
Ford Truck F150 CHECK WHEELBASE X 44341 $400 Rigsbee Auto Parts USA-NC(Knightdale) Request_Quote 1-919-266-3333 Request_Insurance_Quote
199 1990Frame Assembly
Ford Truck F150 133' WHEEL BASE-BARE FRAME X 57419 $400 Rigsbee Auto Parts USA-NC(Knightdale) Request_Quote 1-919-266-3333 Request_Insurance_Quote
199 1987Frame Assembly
Ford Truck F150
212 1990Frame Assembly
Ford Truck F150
214 1990Frame Assembly
Ford Truck F150 WHT,STD,5.0L,AT,2WD,Key X M51442 $Call Marks Used Auto Parts USA-NC(North-Wilkesboro) Request_Quote 336-696-6900 Request_Insurance_Quote
216 1989Frame Assembly
Ford Truck F150 5.0,5 Sp,RWD A 1D6033 $350 Hunt's Auto Parts, Inc. USA-NC(Asheboro) Request_Quote 1-800-672-2113 Request_Insurance_Quote
220 1989Frame Assembly
Ford Truck F150
239
Frame Assembly
Ford Truck F150 *REAR 1/2 ONLY*BLUE&TAN REGCAB A 21212 $175 Schronce Used Parts & Cars, Inc. USA-NC(Conover) Request_Quote 1-800-222-1046 Request_Insurance_Quote
246 1981Frame Assembly
Ford Truck F150
268 1987Frame Assembly
Ford Truck F150
268 1988Frame Assembly
Ford Truck F150
268 1989Frame Assembly
Ford Truck F150
268 1981Frame Assembly
Ford Truck F100
286 1987Frame Assembly
Ford Truck F150
286 1988Frame Assembly
Ford Truck F150
286 1989Frame Assembly
Ford Truck F150
286 1990Frame Assembly
Ford Truck F150
Ford Truck F150 XLT,5.0L,AT,RWD,Tilt X 19011 $Call R & D Auto Parts USA-NC(Shelby) Request_Quote 704-482-9789 / 704-482-4371 Request_Insurance_Quote
Ford Truck F150 K,XL,5.0,4S,4x4 A 20-30 $600 Morrow Motors, Inc. USA-NC(Forest-City) Request_Quote 828-245-7966 / 800-333-7202 Request_Insurance_Quote
294 1985Frame Assembly
Ford Truck F150 V6,AT,RWD,TILT,CRUISE X AA0965 $Call East Coast Used Parts USA-NC(Clarendon) Request_Quote 877-914-4800 Request_Insurance_Quote
310 1990Frame Assembly
Ford Truck F150 5.8,ATOD,RWD,CRUISE X AA1478 $Call East Coast Used Parts USA-NC(Clarendon) Request_Quote 877-914-4800 Request_Insurance_Quote
I dont think he can use anything newer than 86 as that is the last year for our body style and our front bumper will bolt to the frame on.
Why geta newer frame and then need to swap the front frame horns just to bolt the bumper back on.
Also his rusted frame may not be good enough far back with the rust to even use like that?
Dave ----
