Frame Damage Help
Old Apr 20, 2024 | 02:48 PM
neoacacia's Avatar
neoacacia
4wd Low
Frame Damage Help
Hello all. I have a 1986 F-150 and recently took it in to a shop to do a general inspection of the suspension system and they called me back saying my truck is "done." Is this damage to the frame repairable? What can be done? I dont want to junk this truck.
Old Apr 20, 2024 | 04:27 PM
Franklin2's Avatar
Franklin2
What is the body like? You will definitely need a replacement frame from the wreckers or a donor you get off marketplace. You must live up north somewhere. I am surprised you made it to the shop. That rot is near the steering box. That area takes a lot of strain, even on a frame with no rot.
Where do you live? We might be able to find a donor if you want to change the frame out.
Old Apr 20, 2024 | 04:28 PM
Franklin2's Avatar
Franklin2
P.S. Longbed, shortbed, 4x4, etc.
Old Apr 20, 2024 | 05:31 PM
BigBlue2's Avatar
BigBlue2
This is what happens to any frame exposed to liquid deicer and not treated with a good anti corrosive. Only takes a few years of exposure to achieve that kind of corrosion. You can even move away from saltlandia and if you don't treat your frame and body the MgCl salts stick like glue and reactivate each time it gets wet from rain.
Old Apr 20, 2024 | 07:14 PM
FuzzFace2's Avatar
FuzzFace2
X2 what Franklin said "I am surprised you made it to the shop. That rot is near the steering box. That area takes a lot of strain, even on a frame with no rot."!
Have you looked the rest of the frame over really good? Rear spring brackets are also known for rusting out.
I would say if the rest of the frame is good and you cant find a full frame for replacement maybe you can find just that front part of the rail back behind the cross member.
It is work but you could then trim your frame and weld in the good one. You can use grade 8 bolts and nuts for the cross member to frame rail where the rivets were.
Might be easier to replace that part of the frame with motor removed.
Dave ----
Old Apr 20, 2024 | 09:55 PM
neoacacia's Avatar
neoacacia
4wd Low
The body is in great shape. And yes I live outside Philly. The truck is from the Poconos. I've been driving this daily, going across the Delaware River for work commute, delivering food, moving furniture from a recent move 2 weeks ago. Scary to think I could have killed myself and didn't even know it.
Old Apr 21, 2024 | 08:38 AM
Franklin2's Avatar
Franklin2
I am sure looking at the frame, that the steering was a little vague. You probably chalked it up to being a "old truck". If the body is in good shape, then it would be worth it find another frame and slip it underneath. If you look for another frame, I would look for a 2wd frame in your area, even if yours is 4wd. They are the same except the rear spring brackets and they can be easily changed. I am thinking a 2wd frame will not be rotted out like a 4x4 frame would be, since the 4x4 would tend to be driven more in the winter slush.
Best would be to make a trip out of it and go south to get yourself a frame, The further south you go, the better. It's amazing to me what North Carolina trucks look like compared to the ones here in Va. My daughter lives in Pa and I know you guys have it even worse than we do.
Old Apr 21, 2024 | 09:54 AM
neoacacia's Avatar
neoacacia
4wd Low
So the steering actually just recently became an issue. The steering wheel would be at like 3 o clock for driving straight, and the truck started to sway left to right while driving. The right front tire tread wore down quickly to the point the wires were showing. This all just happened in the past month. Before then, there were no noticeable issues. That's what led me to taking it in to the shop, figuring I had some kind of suspension issue. I'm just surprised that the frame is now broke, it seems so sudden and out of nowhere. The body is not immaculate, there's some knicks and scratches, the paint is faded but still looks good, there's some rust spots on the tailgate. For an almost 40 year old truck I think it's in pretty damn good shape. The engine runs strong. Only ever got stuck one time in my 2 years owning it, and that was just an alternator belt breaking. I would hate to junk this truck if there's a way I can fix it. And btw it is a 2wd 8ft bed. I'm very ignorant on all of this, but how exactly does one go and get a frame?
Old Apr 21, 2024 | 10:17 AM
FuzzFace2's Avatar
FuzzFace2
So any F100 / F150 from 80 to 86 in 2WD and 8 foot bed will work.
Think F250 in 2WD would work also it would be just a little more HD but the above trucks will be 100% good to use.
You can check CL or FB market place and local junk yards.
For CL & FB look for trucks with rusted bodys, check the frames really really good dont want to buy what you got now, no motor / running gear as you can get them cheap as most of the time they just want to get rid of what they got sitting there.
All you really want is the frame, the rest once the frame swap is complete you can sell the good parts to get some money back in your pocket.
The only thing to watch out for is with frame swaps there is a VIN stamped on it and this will no longer match the VIN on the cab door sticker or windshield.
This is only an issue if you sell the truck and DMV goes looking at the VIN's or if someone goes looking for them.
If you can get the title for the good frame that helps. Vary min is a bill of sale with the new frames VIN on it.
Junk yards will know what has to be done with the VIN and they would give you a BoS.
When I gave my parts truck frame away I did not send the title or BoS with it, I forgot to, but if he reaches out I will sent it.
Dave ----
Old Apr 21, 2024 | 10:19 AM
BigBlue2's Avatar
BigBlue2
You're going to need a donor truck or a frame from another truck. Check your local wrecking yards for one or search on line
https://car-part.com
Old Apr 21, 2024 | 10:33 AM
BigBlue2's Avatar
BigBlue2
I saw an article in AAA magazine a while back. Based on receipts from Triple A shops they said 3 billion a year in salt damage repairs. That was years ago so with inflation and non Triple A shops and DIYers you can probably factor that number by at least 10.
Old Apr 21, 2024 | 10:46 AM
neoacacia's Avatar
neoacacia
4wd Low
Dave ----
What is a good way to check the frame to make sure it's worth it to buy? I'm not familiar with this stuff. And the frame for my truck I was under the impression it was good and solid. From my own eyes and from what others told me as well.
Old Apr 21, 2024 | 12:24 PM
Franklin2's Avatar
Franklin2
In your area, you will need to be very careful. Most frames will have rust up there. You will need to be less careful the further south you go. You still need to be careful, sometimes you get a northern transplant down south.
Tons of them in North Carolina. Reasonably priced also. Just make sure the price includes them taking the frame out from under the donor truck at the yard. Once they get it out you can look it over easily. You will also need to check for accident damage.
1986
Frame Assembly
Ford Truck F150 2DR,4X2 A M1F041 $350 Andrew's Automotive and Salvage USA-NC(Hillsborough) Request_Quote 919-241-4211 Request_Insurance_Quote
180 1987
Frame Assembly
Ford Truck F150 133' WB, 4x2,2DR,RWD,SURFACE RUST A S2I083 $350 Andrew's Automotive and Salvage USA-NC(Hillsborough) Request_Quote 919-241-4211 Request_Insurance_Quote
180 1985
Frame Assembly
Ford Truck F150 CHECK WHEELBASE X 44341 $400 Rigsbee Auto Parts USA-NC(Knightdale) Request_Quote 1-919-266-3333 Request_Insurance_Quote
199 1990
Frame Assembly
Ford Truck F150 133' WHEEL BASE-BARE FRAME X 57419 $400 Rigsbee Auto Parts USA-NC(Knightdale) Request_Quote 1-919-266-3333 Request_Insurance_Quote
199 1987
Frame Assembly
Ford Truck F150 133' WB, 4x2,4X2,4/87 A J0054 $350 21 Motors USA-NC(Hamptonville) Request_Quote 336-468-8257 Request_Insurance_Quote
212 1990
Frame Assembly
Ford Truck F150 133' WB, 4x4, REAR HALF A 9G0809 $200 B & D Motors USA-NC(Roaring-River) Request_Quote 336-984-4343 Request_Insurance_Quote
214 1990
Frame Assembly
Ford Truck F150 WHT,STD,5.0L,AT,2WD,Key X M51442 $Call Marks Used Auto Parts USA-NC(North-Wilkesboro) Request_Quote 336-696-6900 Request_Insurance_Quote
216 1989
Frame Assembly
Ford Truck F150 5.0,5 Sp,RWD A 1D6033 $350 Hunt's Auto Parts, Inc. USA-NC(Asheboro) Request_Quote 1-800-672-2113 Request_Insurance_Quote
220 1989
Frame Assembly
Ford Truck F150 133' WB, 4x2,2DR,RWD, WE SHIP A V1214171 $Call Doug's Auto Sales & Salvage USA-NC(Chocowinity) Request_Quote 252-946-9820 Request_Insurance_Quote
239
Old Apr 21, 2024 | 12:25 PM
Franklin2's Avatar
Franklin2
Frame Assembly
Ford Truck F150 *REAR 1/2 ONLY*BLUE&TAN REGCAB A 21212 $175 Schronce Used Parts & Cars, Inc. USA-NC(Conover) Request_Quote 1-800-222-1046 Request_Insurance_Quote
246 1981
Frame Assembly
Ford Truck F150 XLT,4.9,AT,RWD,NO KEY X 234570 $Call Hoopers Used Auto Parts USA-NC(Dallas) Request_Quote 704-922-0465 Request_Insurance_Quote
268 1987
Frame Assembly
Ford Truck F150 5.0,AT,RWD,KEY X 240431 $Call Hoopers Used Auto Parts USA-NC(Dallas) Request_Quote 704-922-0465 Request_Insurance_Quote
268 1988
Frame Assembly
Ford Truck F150 XLT,5.8,AT,RWD,KEY X 240489 $Call Hoopers Used Auto Parts USA-NC(Dallas) Request_Quote 704-922-0465 Request_Insurance_Quote
268 1989
Frame Assembly
Ford Truck F150 XLT,5.0,AT,RWD,NO KEY X 240916 $Call Hoopers Used Auto Parts USA-NC(Dallas) Request_Quote 704-922-0465 Request_Insurance_Quote
268 1981
Frame Assembly
Ford Truck F100 2WD,REGCAB,4.9,4SP,BLK X E628 $Call L and L Auto Parts, Inc. - PRP Freight, CDC USA-NC(Grover) Request_Quote 704-487-7401 / 704-937-9333 / 800-289-5474 Request_Insurance_Quote
286 1987
Frame Assembly
Ford Truck F150 5-87,5.0,XL,4X4,AT X F618 $Call L and L Auto Parts, Inc. - PRP Freight, CDC USA-NC(Grover) Request_Quote 704-487-7401 / 704-937-9333 / 800-289-5474 Request_Insurance_Quote
286 1988
Frame Assembly
Ford Truck F150 3-88,5.0L,RWD,F4,CUSTOM X L313 $Call L and L Auto Parts, Inc. - PRP Freight, CDC USA-NC(Grover) Request_Quote 704-487-7401 / 704-937-9333 / 800-289-5474 Request_Insurance_Quote
286 1989
Frame Assembly
Ford Truck F150 01-89,4.9,4X2,AT X L491 $Call L and L Auto Parts, Inc. - PRP Freight, CDC USA-NC(Grover) Request_Quote 704-487-7401 / 704-937-9333 / 800-289-5474 Request_Insurance_Quote
286 1990
Frame Assembly
Ford Truck F150 BLUEXT,REGCAB,2WD X C052 $Call L and L Auto Parts, Inc. - PRP Freight, CDC USA-NC(Grover) Request_Quote 704-487-7401 / 704-937-9333 / 800-289-5474 Request_Insurance_Quote
286 1990
Frame Assembly
Ford Truck F150 XLT,5.0L,AT,RWD,Tilt X 19011 $Call R & D Auto Parts USA-NC(Shelby) Request_Quote 704-482-9789 / 704-482-4371 Request_Insurance_Quote
286 1987
Frame Assembly
Ford Truck F150 K,XL,5.0,4S,4x4 A 20-30 $600 Morrow Motors, Inc. USA-NC(Forest-City) Request_Quote 828-245-7966 / 800-333-7202 Request_Insurance_Quote
294 1985
Frame Assembly
Ford Truck F150 V6,AT,RWD,TILT,CRUISE X AA0965 $Call East Coast Used Parts USA-NC(Clarendon) Request_Quote 877-914-4800 Request_Insurance_Quote
310 1990
Frame Assembly
Ford Truck F150 5.8,ATOD,RWD,CRUISE X AA1478 $Call East Coast Used Parts USA-NC(Clarendon) Request_Quote 877-914-4800 Request_Insurance_Quote
Old Apr 21, 2024 | 12:45 PM
FuzzFace2's Avatar
FuzzFace2
Do I see some 88 and newer listings even a 90?
I dont think he can use anything newer than 86 as that is the last year for our body style and our front bumper will bolt to the frame on.
Why geta newer frame and then need to swap the front frame horns just to bolt the bumper back on.
Also his rusted frame may not be good enough far back with the rust to even use like that?
Dave ----
