2007 - 2014 Expedition & Navigator 2007, 2008, 2009, 2010, 2011, 2012, 2013 and 2014 Ford Expedition and Lincoln Navigator
Bilstein rear shock install
Old Apr 20, 2024 | 02:04 PM
Bccamper's Avatar
Bccamper
3rd Gear
Hi all,
I'm trying to install rear bilstein 5100 in my 2014 navigator l.
I need to swap spring holder over from my original shocks but they are alot bigger diameter. They still have fomoco stickers on them so I can assume that they are oem.
Any suggestions?
Old Apr 21, 2024 | 01:11 PM
aldridgec's Avatar
aldridgec
What part number did you get. I've never used bilsteins on this platform, but I've never had a problem with them on other applications. They're too big with the circlip in place and go over it?
Old Apr 21, 2024 | 06:43 PM
Bccamper's Avatar
Bccamper
3rd Gear
I verified correct part number. The original shock body is supposed to be the same diameter so spring rest could be swapped.
The one i have are over 3/4 of an inch bigger and they look to be welded.
I just wish bilstein would come with a new rest.
i guess i will just return them and install oem
Ty for your time
Old Apr 22, 2024 | 07:41 AM
aldridgec's Avatar
aldridgec
Alright. Keep in mind you may run into the same issue still. Do you have the HD trailer tow? I can't remember if they did it by the 2014 MY but at some point they ditched the air suspension and went to Nivomat load leveling shocks which typically have a bigger body. Catalog still shows it but I don't know why the shock body would be that large otherwise.
Dgriff804
1997 - 2003 F150
Mar 29, 2018 02:02 AM
week0019
2004 - 2008 F150
Jul 26, 2011 12:07 PM
blloyd
May 15, 2011 04:31 PM
Grabber
Oct 17, 2007 07:42 PM
Poolpro
Jul 30, 2003 03:23 PM
