Track Bar Torque
Old Apr 18, 2024 | 03:15 PM
eptesicus's Avatar
eptesicus
5th Gear
Originally Posted by satxuser
My track bar spec’ed 250# on the tie-rod end and 406# on the frame end. Please share what you use in order to get to the 406# (tools, techniques etc.). Thank you in advance.
I have a 4-foot or so long 100-700# torque wrench that I'll use here in a few to torque it down to 406# on the frame-side. I'll get the truck on the ramps to have some more room to make it happen.
Old Apr 18, 2024 | 05:29 PM
AKTremor33's Avatar
AKTremor33
4wd Low
Originally Posted by speakerfritz
If you get a click/pop on slow turns you will need to increase from the 250lb. I doubt 250lb will be enough.
This. I just had the BDS track bar installed. Shop apparently went to 350# the first time, but between that torque and the bushing settling I got the poping and bolt movement. Just had it redone to 410# and so far so good.
Old Apr 18, 2024 | 07:57 PM
Rwhjr's Avatar
Rwhjr
I have the proper torque wrenches. I’m going to go to 406 and call it a day.
Old Apr 18, 2024 | 08:53 PM
Quad Racer's Avatar
Quad Racer
I’ll have my new favorite shop torque it down if I ever swap it. But for now I’m good to go with the stock.
Old Apr 18, 2024 | 11:14 PM
Joe T's Avatar
Joe T
Originally Posted by Joe T
Is it different on both sides?
I just rented a wrench at Autozone. This isn’t a blueprinted high rev engine needing exact torque specs.
I meant to say 3/4” torque wrench.
You can get an adapter to take it down to 1/2” off amazon or at harbor freight.
Old Jul 12, 2024 | 09:00 AM
westracing01's Avatar
westracing01
Hate to bump this but I don't think it needs a new thread...
Any recommendations on a decent torque wrench that's not $700+ to do that frame side bolt? I was thinking of getting a new impact wrench capable of going way past 400ft/lbs and just going a bit easy on it but get it good and tight, but if I can get a reasonable torque wrench for the same kind of bread I'd rather know the thing is torqued properly. That's not a bolt you want to fool with being loose.
Old Jul 12, 2024 | 09:09 AM
speakerfritz's Avatar
speakerfritz
https://www.harborfreight.com/34-in-...ter-58707.html
Old Jul 12, 2024 | 09:53 AM
Joe T's Avatar
Joe T
Are you doing it often professionally? If not just rent it. I use Autozone, and yes they said they calibrate them. I used a 1/2” reducer too so I didn’t have to buy an expensive socket.
Old Jul 12, 2024 | 10:33 AM
westracing01
I was wondering if that was worth a damn or not. If it is, then sure, I'd go that route and just slap it on the 3/4 ratchet with some pipe I already have.
No, certainly not. I don't mind spending money on tools though. I find that things I buy for one specific job I often wind up using on other stuff.
Old Jul 12, 2024 | 12:35 PM
morehouse7's Avatar
morehouse7
I have that one from Harbor Freight, seems ok. I use my Milwaukee to set that bolt and it is was past the 406 ft lb any time I check.
I am in Goshen if you want to borrow the torque adapter and big breaker.
Old Jul 12, 2024 | 02:03 PM
westracing01
Cool, thank you! Won't be anytime soon. Just plotting for now.
Old Jul 12, 2024 | 03:25 PM
4wd6.7L's Avatar
4wd6.7L
My local Autozone, and Orielly’s for that matter, only have torque wrench rentals that go up to 250 ftlb.
Old Jul 13, 2024 | 08:02 AM
  #28
kylant's Avatar
kylant
i just picked up 2 from amazon. went with the highest rated ones. they look to be pretty decent. will probably send one back.
one goes to 400 ft/lb the other to 650.
Old Jul 13, 2024 | 03:28 PM
  #29
Joe T's Avatar
Joe T
They have to bring it in from their distribution center. I think the deposit was like $360 and I had to wait a few days to get it. I kept it like a week if my memory serves me correctly.
They claim to calibrate it. Thats another good thing because I do not have that ability or desire to mess with that.
SteveO90290
Sep 3, 2022 10:14 PM
reicherb
Dec 8, 2021 03:22 AM
xploded
Apr 30, 2018 02:12 PM
P4IN COMM4NDO
18
Oct 12, 2016 06:09 PM
Treker58
Feb 16, 2011 09:20 PM
