Well I'll start with a little info on the truck, it's a 1977 f250. Drivetrain consists of a carburated 302, E4OD w/ 1356 transfer case and sterling 10.5 and dana 60 axles with 3.73:1 gears.
I have started to consider a cam swap while the engine is being resealed and painted.
Now that's where I'm getting a but unsure, most recommendations I have read through are based on 1:1 final drive ratios and 4:10 gears or something along those lines.
Most cams I see listed specs like lift and duration but that information means nothing to me at the moment, I understand the meaning but that's about all.
Being that I have little experience with older gasoline engine modifications and no experience selecting aftermarket camshafts. I'm hoping someone can guide me in a direction or help me educate myself to make a decent selection myself.
my goal is a little more power and of course the loping idle that we all love to hear.
The engine to my knowledge is stock and has a 600cfm holley carb with an electric choke.
Any recommendations or guidance is appreciated.
The general rule of thumb is that increasing duration moves the torque curve further up in the RPM band, so a high duration cam has poor off idle response but better high RPM response. You also can't get a lot of lift in a small duration cam because there are physical limits on how fast you can ramp open a valve, and there just isn't enough cam lobe available on a short duration cam to get a lot of lift.
If you have stock heads, and are typically running below 3,000 rpm, something in the lower duration range will be the most suitable.
No brainer. call Brent Lykins and get a custom roller cam. only a few dollars more and it's made for your build and vehicle not just a generic small block chevy grind.
Might look into the roller cams Ford used in the last few years of the 5.0 in the explorer and mountaineer. They were supposedly more torque minded than the older 5.0 HO roller cams. Drop in retrofit roller lifters make the swap easy with no machine work required. Also, side note, how are you controlling that E4OD? You said you had a carburetor, but the E4OD is electronically controlled.
Thats an idea I haven't heard, ill look into that, thanks.
The E4OD is being controlled by a Quick 4 stand alone controller in conjunction with a holley TPS kit mounted on the choke side of the carb.
The vehicle speed is read by the oem vss in the transfer case as well as speedo, that uses a mechanical speedo converter from JEGS to retain oem speedo.
