Trouble shooting p1633
I have a 2008 f550 with a 6.8L V10. I recently had the truck lose power when stopping and had the check engine light pop up. Reads code p1633. Battery and alternator reading 14 amps so I’m not sure what’s wrong. I’m thinking it’s the fuse but I could be wrong. Has anyone had this problem before and what’s the best way to resolve it? Thanks!
Ford F150 code P1633 - Search (bing.com)
Ask a Ford Maintenance Question, Get an Answer ASAP! (justanswer.com)
Hope that's some quick help late on a Friday night. A voltage problem existing from the Battery is hard to trace, you just need a VOM and look for bad terminal connections and grounds. also the Fuse boxes do have corrosion problems also. Blue green is a bad sigh on need of new stuff. If you are uncomfortable with this, just call your friendly neighborhood skill shop that you trust. U'r looking at a possible + $300 +.
