ATV help.
Old Sep 24, 2005 | 05:23 PM
maticuno's Avatar
maticuno
ATV help.
I have an '86 Suzuki Quad Runner. At idle, all of the lights work perfectly. The second you give it gas, the lights dim to almost nothing. If the battery was bad, I would think it would do the opposite. Is it the regulator, perhaps? Also...just out of curiosity...how much would one of these things go for? It's a 230 in pretty good shape. $500? $800? Less?
Old Sep 24, 2005 | 08:20 PM
ffemt32ffd's Avatar
ffemt32ffd
I don't have a quad, but it sounds to me like you have a charging problem. Possibly the regulator, it sounds like one of those expensive hard to find problems. Try calling a Suzuki dealer and ask the repair guys how to test it, I had a simmilar problem with a street bike and they told me how to test the parts of the system. I ended up needing a new alternator ($425). Hope you have better luck...
Old Sep 24, 2005 | 09:12 PM
BFR250SD's Avatar
BFR250SD
I had the exact same thing happen to my Grizzly last winter. I thought the same thing about the charging system at first, but the battery was toast. What's happening is the charging system thinks the battery is fully charged and shorts to prevent over-charging. Once this happens, you're lights are only getting the little bit of juice that the battery is providing and it's also trying to provide juice for spark.
Easy way to see if the battery is toast is to put it on a charger and if it show fully charged within a few minutes; it's toast.
I put the new battery in and all was good again.
Old Sep 24, 2005 | 09:22 PM
DOHCmarauder's Avatar
DOHCmarauder
Volt meter anyone???
Old Sep 24, 2005 | 09:41 PM
BFR250SD's Avatar
BFR250SD
You know, I tried that and everything read fine. The battery was still making 12.5 + volts when I put the meter on it, but it couldn't hold it under a load. Everything else was fine.
What tipped me off was when I KNEW the battery was dead (bike wouldn't crank) and I put it on the charger and in about 2 minutes it was reading fully charged. It was really odd.
Oh yeah, pull starting a 660 single sucks!
Old Sep 24, 2005 | 09:58 PM
jrs_big_ford_f150's Avatar
jrs_big_ford_f150
I don't know if you know this but a lot of 4 wheelers have a compression release lever that makes pull starting way easier.
Old Sep 24, 2005 | 10:03 PM
BFR250SD's Avatar
BFR250SD
Yes I know. Mine like many others have the AUTOMATIC compression release. Yeah, automatic my butt. My QM 500 had the manual and that was no problem, but the Griz, wheeeeeew!
You gotta make a couple little pulls to get in the right spot to yank. If you don't, it's rip it right out of your hands.
Old Sep 24, 2005 | 10:05 PM
TK70Ranger's Avatar
TK70Ranger
most of them are automatic de-comp now. I pull started an ATC 200 with a broken auto de-comp lever, it sucked because being as short as I am I couldn't get a good pull on the thing, and the one time I did the run switch was off.
Old Sep 24, 2005 | 10:09 PM
ffemt32ffd's Avatar
ffemt32ffd
If you want to check the battery and don't have a load tester for it take it to a parts store that sells batteries. Most of them will test it for you for free. Just using a volt meter isn't acurate as the battery may maintain it's voltage without being able to flow any current. The voltage needs to be checked while the battery is flowing current (under load).
Old Sep 24, 2005 | 10:36 PM
lariat97's Avatar
lariat97
My Kodiac does that if the battery is dead. I don't ride it much & ruin a battery every 2 yrs. Its a PITA to pull start.
Old Sep 24, 2005 | 11:03 PM
maticuno's Avatar
maticuno
Cool. I put my tester on the battery and it isn't even throwing a full volt. I'll change that out. Now...anyone have any idea on pricing?
Old Sep 25, 2005 | 01:59 AM
BFR250SD's Avatar
BFR250SD
I know mine, dealer price, was $82. Retail was like $118. Yeah, they aren't real cheap.
Old Sep 25, 2005 | 02:13 AM
DOHCmarauder
$35..............Wally World.
Old Sep 25, 2005 | 07:25 AM
GlennFordx4's Avatar
GlennFordx4
I am building one of these right now ground up for the wife(yea right) easy way to test load on battery with out a load tester is put a volt meter on battery and hit the start button then take your reading as far as what it is worth depends on condition around here great shape 1000-1500,good shape 700-900.The 230 I am building is going to be pretty nasty ported, wiseco piston supertrapp exh,larger carb and cam and a twist throttle.I'm a bike guy but the 230 suzuki fits me well only auto that I ever had that would do third gear wheelies
Old Sep 25, 2005 | 11:28 AM
lariat97's Avatar
lariat97
I got my last battery from Autozone for $40. The dealer charges $95 here.
HateMyTruck
New Member Introductions
Nov 10, 2015 08:21 AM
rickrod
Sep 7, 2008 01:02 PM
Chumbucket
Aug 6, 2008 04:09 AM
78bigunns
Sep 18, 2006 09:40 AM
TallPaul
Nov 15, 2001 11:59 AM
