Radiator Replacement
Old Apr 10, 2024 | 02:02 PM
JoePa2's Avatar
JoePa2
Well I'm finally finished with my radiator job on my 1998 Ford Club Wagon with a 5.4 - I mentioned in an earlier post that I had coolant on the garage floor and had a hard time figuring where the leak was coming from - ended up finding a crack on the top plastic part of the radiator - the coolant dripped down the drivers side of the radiator making me think that the leak was there somewhere on the bottom - the hardest thing encountered was taking the bottom radiator hose off the old one - got a new radiator at Auto Zone that cost me 3 hundred - then the hardest thing - trying to put the fan back on after installing the new radiator - I'm 90 years old and don't have the strength I used to have - just couldn't do it with the. shroud in the way - I finally got the fan back on but had to put the it on without the shroud - I cut the Botton of the shroud so I could get that on - after the shroud was on I patched it up. using aluminum tape I had laying around - I used a couple layers of tape and it seems like it its a good repair - felt pretty good doing this job - but it keeps getting harder as the years go by - Joe
Old Apr 15, 2024 | 10:26 AM
Mike1's Avatar
Mike1
I don't think that tape will stay forever. If it were me I'd either drill small holes on either side of where you cut it in two and zip tie it back together or I'd run to Harbor Freight, buy a plastic welder and weld it back together. Good luck with it whatever you decide to do, or not do, but you got the important part done
Old Apr 16, 2024 | 06:09 AM
JWA's Avatar
JWA
If the crack or split can be seen and somewhat easily accessed I'd use a JB Weld product to their cleaning and surface preparation suggestions.
Old Apr 17, 2024 | 08:52 AM
econo93's Avatar
econo93
Originally Posted by JoePa2
..... I finally got the fan back on but had to put the it on without the shroud - I cut the Botton of the shroud so I could get that on - after the shroud was on I patched it up. using aluminum tape I had laying around - I used a couple layers of tape and it seems like it its a good repair - felt pretty good doing this job - but it keeps getting harder as the years go by - Joe
I did similar with mine since I've needed easier access to check the belt, tensioner (air pump delete), misc. leaks,etc. I cut mine in half at top and bottom so there's a left and right that can be removed individually. It makes it easier for me to reach the radiator drain from above when the DS half is removed. I used 3/4" X 2" pieces of flat aluminum stock and pop rivets to hold the halves together and just drill them out when needed.
Bitwise
17
Jul 27, 2023 09:53 PM
Andyinchville1
Apr 30, 2023 05:42 AM
coolfeet
May 10, 2017 07:39 PM
Jack_PA
Jan 12, 2003 10:38 PM
