L91810 = 1971 numerical series, June 1971 production
156 = 156 inch wheelbase
J = Rangoon Red
F702 = F700 gas, 23,000 lbs GVWR
D28
D2 = Black Vinyl
8 = Cab & Chassis vehicle. I can't tell if Custom Cab or Regular
A = New Process model 435 four speed transmission
E2L
E2 = Eaton model 16244 Two Speed Rear Axle / 6.17/8.58 ratios / 17,500 lbs. Rear Axle Capacity.
L = Ford 6,000 lb capacity front axle with power steering
23000 = 23,000 lbs GVWR
164 3800 = 164 certified net HP @ 3800 RPM
530281
53 = Kansas City District Sales Office
0281 = Special Order Number.
All of the Regular Production Order items are present--color, engine, trans, axles, so no clue about what the special order could be.
