Sponsored by: Auxito
daytime lites
Old Nov 25, 2003 | 04:35 PM
djohn's Avatar
djohn
daytime lites
Daytime lites are great, but there are time when you need them off. In my 1996 Ford you could put on the emergency brake and they would go off. But not so in my 2002 150. Any ideas???
Thanks
Old Nov 25, 2003 | 05:01 PM
kspilkinton's Avatar
kspilkinton
Should be an article in the tech section about the system. Unfortunately it removes the daytime running light capability all together. Essentially you remove the relay behind the driver side light and you don't have them anymore.
You might think about a secondary switch that involves routing the light output through it. THis way you can switch the lights on and off.
-Kerry
Old Nov 26, 2003 | 12:49 PM
djohn's Avatar
djohn
Thank you Kerry, I'll try that...
Djohn
Old Nov 26, 2003 | 12:55 PM
MrBSS's Avatar
MrBSS
I've found that on my truck, applying the emergency brake does not turn off the DRL's if they are already on, however applying it before they come on does prevent them from coming on. Maybe yours is similar.
Old Nov 26, 2003 | 01:32 PM
djohn's Avatar
djohn
Neat, I just had to run out and try it.....I put on the emergency brake turn on the key to "run" lites came on.....damn, thanks for the suggestion though
djohn
Old Nov 27, 2003 | 10:56 AM
kspilkinton
Djohn (or anybody else),
I'm not familiar with the Canadian transportation laws that govern the day time running lights. Is it a law to have them? I know they come standard on all new Canadian vehicles and have for a number of years. Around here, in western Washington, we used to have signs on the road that let us know we need to put the lights on. Haven't seen them in a while.
-Kerry
Old Nov 27, 2003 | 02:08 PM
djohn's Avatar
djohn
I am pretty sure that it is a Canadian law. And I agree with it. In my line of work Road maint. I am amazed at how many people do not have their lights on during a snow storm. Usually they are driving a white or grey auto.
In my work there are times when I need to park on side of the road (winter) and I need to observe without being observed.
Djohn
Old Nov 27, 2003 | 06:10 PM
Racerguy's Avatar
Racerguy
Starting in 1990 (I think) all cars and light trucks had to have DRLs. Even if they weren't mandatory I think they are a good idea.
With a little bit of work you could add a switch to shut off the DRLs. You would have to put the switch in the Og/LG wire from the underhood fuse box to the DRL resistor which is behind the front bumper on the driver side.
Djohn where in BC are you?
Old Nov 28, 2003 | 09:43 AM
djohn's Avatar
djohn
Hi Dave
Thanks for your thoughts, That is probably the best option, and I will add a warning lite on the dash too - just as a reminder the DRL are off.
I am from Spallumcheen (I'll let you look that one up :-)
Old Nov 28, 2003 | 04:19 PM
Racerguy's Avatar
Racerguy
I believe I've been through Spallumcheen on my way from my brother in law's place in Sicamous to Kelowna
Old Nov 28, 2003 | 08:50 PM
98f1504x4ohio's Avatar
98f1504x4ohio
what about adding DRL's to a truck that doesn't have them? is it as simple as popping a relay into place?
Old Nov 29, 2003 | 11:43 AM
kspilkinton
Yeah, For 1998 and earlier, you'll need the relay that goes under the passenger side dash cover. Part number F65Z-15A272-AA
Try this link for more info.
-Kerry
Old Dec 6, 2003 | 02:46 PM
HUBBELL's Avatar
HUBBELL
RUNNING LIGHTS
IT IS A PAIN TO INSTALL. I HAD MY BUDDY PUT THEM IN ON MY EXPEDITON AND F-150. TOOK HIM A COUPLE HOURS ON EACH VEHICLE
CougarXR02
15
Apr 19, 2021 04:27 PM
THATfarm94
6.4L Power Stroke Diesel
Feb 3, 2018 09:39 AM
surreyboy
6.7L Power Stroke Diesel
Nov 2, 2015 12:07 PM
Tugnut
1997 - 2003 F150
Apr 4, 2015 12:26 PM
Quest1
Escape & Escape Hybrid
Sep 26, 2014 09:45 PM
