2010 F250 daytime running lights - Ford Truck Enthusiasts Forums
Go Back  Ford Truck Enthusiasts Forums > Diesel > 6.4L Power Stroke Diesel
Reload this Page >
6.4L Power Stroke Diesel Engine fitted to 2008 - 2010 F250, F350 and F450 pickup trucks and F350 + Cab Chassis
Old 02-03-2016, 03:48 PM
THATfarm94
THATfarm94 is offline
THATfarm94 is starting off with a positive reputation.
Hey everyone
I have a 2010 F250 Harley Davidson truck. I really want to get my daytime running lights to turn off. I went to the dealer and they disabled the DRL's but they still stay on went the truck is running. The headlight switch is functioning correctly and so is the rest of the system. If y'all have an idea to why they are still on I would be great full for the advice.
Old 02-19-2016, 04:06 PM
Mixer man's Avatar
Mixer man
Mixer man is online now
Journeyman Apprentice
Mixer man has much to be proud ofMixer man has much to be proud ofMixer man has much to be proud ofMixer man has much to be proud ofMixer man has much to be proud ofMixer man has much to be proud ofMixer man has much to be proud ofMixer man has much to be proud ofMixer man has much to be proud ofMixer man has much to be proud of
I'm curious what the dealer did to supposedly disable the DRL's? Apparently it didn't work (hope you didn't have to pay them for that). I had that issue with a Tundra awhile back but the dealer wouldn't do it. I got a hold of a schematic and found a junction connector under the driver's side fenderwell. Unplugged it and taped it off, problem solved. Maybe Ford is similar.
Old 02-19-2016, 05:59 PM
slowmans's Avatar
slowmans
slowmans is offline
slowmans has a good reputation on FTE.slowmans has a good reputation on FTE.
I don't have DRL in my 10'?
Old 02-19-2016, 06:21 PM
Mixer man's Avatar
Mixer man
Originally Posted by THATfarm94 View Post
Hey everyone
Have you tried pushing the headlight switch in? This would turn off the fog lights. What are you calling DRL's? Got a pic?
Old 02-19-2016, 10:12 PM
eberlestock's Avatar
eberlestock
eberlestock is offline
eberlestock has a good reputation on FTE.eberlestock has a good reputation on FTE.
On the older ford obs trucks, when you put the e-brake on the daytime runners turned off. On those trucks there was a switch on the park brake. You put a ground wire form the switch to somewhere handy and the lights stayed off. Not sure if the newer duties can be manipulated the same way??
Old 02-03-2018, 10:39 AM
rixter99
rixter99 is offline
rixter99 is starting off with a positive reputation.
I know this is an older post, but you can do this now if you download FORScan, buy an ODBII adapter and change (enable/disable) this yourself...It's actually an option in the IP Module (not the IP Module 'As Built' module)...I just enabled the DRL on my '08 F250 using this method...Still trying to figure out how to change from 50% Low Beams to Turn Signals or Parking lights...
lilpanther
04-09-2017 04:52 PM
2010FORDF350
1999 to 2016 Super Duty
02-25-2017 04:05 PM
1959
2017+ Super Duty
31
02-16-2017 08:19 AM
comsupany
05-16-2016 01:56 AM
Poncho450
03-20-2016 10:18 AM
Quick Reply: 2010 F250 daytime running lights
Contact Us About Us Archive Advertising Cookie Policy Privacy Statement Terms of Service
  • Ask a Question
    Get answers from community experts
Question Title:
Description:
Your question will be posted in:
