Starter issues
Old Apr 6, 2024 | 11:55 AM
Agavila73's Avatar
Agavila73
6th Gear
Starter issues
I have a 1994 Ford F150 5.0 and I don't think the starter is wired correctly. The wire from the + battery post is in the top bolt and where the small pigtail goes there is another wire from the + battery post. I do not see a ground of any kind attached to the starter at all. When I turn the key the engine will not turnover, it tries to slowly but then it just stops turning over.
Old Apr 6, 2024 | 01:15 PM
Franklin2's Avatar
Franklin2
No ground needed, any ground the starter needs it gets from it's mounting to the engine.
You have a later engine, and I think Ford did go to the chevy type starters with the solenoid on the starter. Do you have the regular Ford solenoid on the fender or firewall also?
Agavila73
16
Apr 11, 2024 12:38 PM
3722
Mar 28, 2023 07:16 PM
joewaldner
39
Feb 13, 2008 11:29 AM
dracip
Jan 28, 2008 06:43 PM
Mulletwagon
Electrical Systems/Wiring
Aug 6, 2001 04:08 PM
