Door Panel Removal
Old Jan 4, 2002 | 06:01 AM
rbrad9753's Avatar
rbrad9753
Door Panel Removal
[updated:LAST EDITED ON 04-Jan-02 AT 07:03 AM (EST)]2000 X Limited V10 4X4, Can someone tell me how to remove the rear door panel without damaging it. I have not yet purchased a repair manual. Hey Monsta maybe this is a good time to check out your new CD that you bought on E-Bay.
Thanks in advance.
Old Jan 4, 2002 | 08:46 AM
Monsta's Avatar
Monsta
Sit. Stay.
Door Panel Removal
Removing them is pretty straight forward. Start on top, inside part of the panel. Use a WIDE flat device to pull back the panel enough to get your fingers under, and pull. They are "push to fit" panels. There are about 7-9 plastic push pins thingies that hold it onto the door. Just be careful. Only exert pressure at a point closest to the pin you're trying to remove. What I'm saying is DON'T grab one end and just yank the whole thing off. You'll see once you get the first off, using care, it's pretty easy.
Why you removing them? Are you putting the optional storage bin ones on there?
Old Jan 4, 2002 | 08:51 AM
rbrad9753's Avatar
rbrad9753
Door Panel Removal
Thank you Monsta for the reply. I am removing them because the power door lock actuator needs to be replaced. The truck just went off warranty about 1,000 miles ago so I figured I would tackle this job myself.
Old Jan 4, 2002 | 03:22 PM
Monsta's Avatar
Monsta
Sit. Stay.
Door Panel Removal
[updated:LAST EDITED ON 04-Jan-02 AT 04:23 PM (EST)]>Thank you Monsta for the reply. I am removing them because
HEY I told you how to remove the rear CARGO door panel. NOT the rear door. OOPS!
I'm sorry!! Re-post or e-mail me and I will send you the instructions. Crap...hope you didn't already try to do it.
Old Jan 5, 2002 | 03:58 PM
GeeBee's Avatar
GeeBee
Door Panel Removal
Old Jan 7, 2002 | 06:25 AM
rbrad9753's Avatar
rbrad9753
Door Panel Removal
Thanks Monsta for the reply. I have not tried to remove the door panel yet. I'm sorry that I wasn't clear enough in my original question. I should have said the rear passenger door to make it more clear.
reamer
May 20, 2014 05:06 PM
ZFamly
Jan 29, 2011 11:20 AM
billy13
Dec 14, 2009 10:29 AM
dmcenery
2004 - 2008 F150
Oct 25, 2008 09:52 AM
Tempe
Jul 7, 2003 01:20 AM
