Any experts on trailer decking here?
Old Mar 31, 2024 | 11:31 AM
One Sock's Avatar
One Sock
I have a 14,000-lb GVWR gooseneck trailer with a 24 foot wood deck. The deck is 2x8's and they are getting to be in pretty bad condition so I want to replace them. At Lowes they have 20 foot Douglas Fir 2x8's for $20, but 24 foot (special order) is $76 each. I checked with independent lumber yards and they're even more expensive.
I'm wondering if it's acceptable to use shorter boards and stagger them? Do 53-foot semi trailers have staggered boards, or do they have to use 53 foot long boards?
Old Mar 31, 2024 | 01:05 PM
helifixer's Avatar
helifixer
My 30 foot gooseneck had 20 foot and 10 foot boards, the joints were staggered.
Old Mar 31, 2024 | 08:45 PM
Tpayne621's Avatar
Tpayne621
You can stagger them no issues. Just do it over the center of a crossmember.
Old Apr 1, 2024 | 06:27 PM
FuzzFace2's Avatar
FuzzFace2
Have you checked with a lumber mill for ruff cut?
I would think it would be cheaper than finished.
Dave ----
Old Apr 3, 2024 | 06:58 PM
Sparky04SD's Avatar
Sparky04SD
Rough cut would be my choice as they are a true 8" wide rather then 7.5" and 2" thick rather then 1.5" for a much improved strength over a finished board.
Old Apr 6, 2024 | 05:15 PM
superrangerman2002's Avatar
superrangerman2002
Stagger the ends every other board end for end and you should be fine.
above ground treated boards are best.
Don’t cheap out with rough cut…all you’ll have is split boards and crappy deck that leaves splinters everywhere in short order.
Old Apr 7, 2024 | 09:19 AM
skid mark's Avatar
skid mark
I agree with the others. Either 20' and 4', or 16' and 8', staggered.
If you have easy access to a welder, I also like to weld a piece of angle iron to both of the two frame members where the boards will meet. This provides more room where the two boards butt together so the fasteners don't have to be so close to the end of the boards.
Old Apr 23, 2024 | 10:15 AM
One Sock's Avatar
One Sock
Yeah, that is my main concern, having the fasteners too close to the ends. I don't have a welder, but I could maybe bolt some angle iron to the current frame members.
jmtbiggin
All Things Towing
13
Jun 11, 2014 09:43 AM
lowcountry
All Things Towing
Apr 2, 2008 10:30 PM
sublimecharger68
All Things Towing
May 10, 2007 08:28 AM
tomrooster-1
General Automotive Discussion
Mar 11, 2005 08:59 PM
Buckarcher
All Things Towing
Sep 18, 2004 08:52 AM
