Electrical issues DDM….
Old Apr 8, 2024 | 08:15 PM
Cmelde01's Avatar
Cmelde01
Originally Posted by Don Ridley
Are you still getting the "U" communication errors?
I would look for PIDs associated the the DDM. Maybe you can determine of the module is sending a signal but it's not making it to the mirror.
No I have not codes as of now. Per the workshop manual I was looking at for the 21 model, I believe the ddm only controls the led light for the telescope switch. The other wires go from the switch, to the non serviceable relay at the bjb then back to the mirror connector if I’m reading it correctly.
Old Apr 8, 2024 | 10:11 PM
ifrythings's Avatar
ifrythings
Sounds like the BJB got water in it, there is a recall for that I believe, not sure if it's applicable for you or not. I don't know what else to suggest but here is 2021 wiring diagrams for your truck.
wh-7
Apr 12, 2024 09:25 AM
bronc93
Feb 12, 2009 04:31 PM
flat540
May 17, 2007 09:02 PM
precords
Aerostar
Jul 17, 2006 07:23 PM
Firefighter631
1997 - 2003 F150
Jun 1, 2005 06:02 PM
