Transfer case stuck 4-low
Old Mar 25, 2024 | 01:17 PM
music9704's Avatar
music9704
Trailering
1995 F250, Manual Case, Lock in Hubs. E4od
I stopped at a stop sign, and the truck would'nd move. (like neutral). When I put the truck in park the gears grinded. Later, I was able to get the truck home in 4 wheel drive. Now the truck is stuck in 4-low. The floor shifter will go thru all stages. When I put the shifter in 4x4 neutral the truck is still driveable.
So do you think its two seperate issues, the trans and case? I did not have it in 4 wheel prior to it "not moving" at the sign. Only after;
From readinig, I'm assume, the problem with the case, is either the linkage or more likely a bad fork, but I'm not sure because of the other issue. The PCM?
Old Mar 25, 2024 | 01:39 PM
Mudsport96's Avatar
Mudsport96
Get under the truck and try to put it in a different range by hand. If it still stays in low range then it is a case problem. It almost seems like maybe the linkage is not connected
Old Mar 26, 2024 | 05:15 AM
manicmechanic007's Avatar
manicmechanic007
A manual shift case
The best option to get, those hubs too
Nice
Your shift forks may have broken and missing plastic tabs that prevent a good positive transfer case shift
Old Apr 24, 2024 | 02:41 PM
music9704's Avatar
music9704
Trailering
Replaced the shift fork, it was broke.
Thanks
DaytonaTunnel
Dec 15, 2013 07:11 PM
conyers73
Dec 12, 2013 07:31 PM
CWPottenger
Mar 2, 2011 04:19 PM
DarylZ
Oct 17, 2005 08:27 PM
fordmann
Dec 28, 2004 10:37 PM
