2007 - 2014 Expedition & Navigator 2007, 2008, 2009, 2010, 2011, 2012, 2013 and 2014 Ford Expedition and Lincoln Navigator
2011 Navigator poor idle after engine flush
Old Mar 25, 2024 | 01:02 PM
zamistro's Avatar
zamistro
Trailering
My mechanic recommended an engine flush to see if a sticky lifter might be freed and quiet the tapping noise on my 5.4. It didn't, but a lot of crud came out of that flex fuel engine.
I realized, too late, that in the same way a flush might be a bad idea for an old transmission of uncertain service history an engine flush might cause problems instead of fix them. My 216k, noisy engine still ran quite smooth. Less than 5 miles after the flush it started with the poor idling. It's favorite trick now is to quit when shifting from drive to reverse. What happened?
Old Mar 25, 2024 | 10:06 PM
aldridgec's Avatar
aldridgec
Hard to say what you dislodged and cause to happen.
The noise wasn't a sticky lifter but a failed follower. Your engine needs repair.
Old Mar 31, 2024 | 09:24 AM
meborder's Avatar
meborder
Id check the VCT solenoids to see if the screens are all clogged up.
John Tillotson
Apr 25, 2021 11:31 PM
Grand Canyon
Computer Chips & Tuners
15
Nov 25, 2006 08:08 PM
Katmandu2
Aug 16, 2003 05:26 PM
Russ8393
Jan 12, 2003 03:53 PM
