Help
Old Mar 17, 2024 | 03:26 PM
DoubleJ1203's Avatar
DoubleJ1203
1st Gear
Help
Where does this go? Comes off of a port on the carb and was just hanging there. 1978 F100 300 6 cyl.
Spent over two hours trying to figure out where this goes to and I'm stumped.
Old Mar 17, 2024 | 05:03 PM
77&79F250's Avatar
77&79F250
Moderator & parts slinger
Vacuum diagrams here, scroll a bit to get to the 6 cly ones.
https://www.ford-trucks.com/forums/1...l#post20821317
Old Mar 17, 2024 | 05:34 PM
redroad's Avatar
redroad
I'm pretty sure that feeds the part of the choke that is hot air and goes to/through the exhaust manifold?
Old Mar 17, 2024 | 07:14 PM
52 Merc's Avatar
52 Merc
It looks like the short stub end that is supposed to go into a hole in the exhaust manifold, or other similar place that would pick up hot air, has broken off. Look around in the area where it dangles and see if you can find a small hole with a piece of tubing in it. That'll be the spot it goes to.
Old Mar 17, 2024 | 07:46 PM
JimsRebel's Avatar
JimsRebel
Here a link to a post with a photo.
https://www.ford-trucks.com/forums/1...l#post21122308
The line in your hand is the fresh air IN. Which connects to the bottom, hot air out the top feeds the "hot air choke".
Search " hot air choke" for more photos and repair info.
Or install a manual choke.
Good luck, Jim
Old Mar 17, 2024 | 08:50 PM
52 Merc's Avatar
52 Merc
Here's the photo in that link. It might give you a better idea of where to look.
cdsleep
Jun 2, 2021 12:59 PM
cdsleep
Jun 1, 2021 06:59 PM
jcormiea
16
Oct 8, 2017 08:57 AM
Gembone
Mar 19, 2013 03:37 PM
